Any help?
Hello, on my 95 GMC the steering wheel has the air bag. I want to change a part in the column but Im a bit concerned about that bag. First how do you get the center off? Does it just pull? I do not see any screws. Next, anyone got a proper procedure for disconnecting the air bag so I can pull off the steering wheel?
                      Thanks, Mike
Hey Mike,
Check out my link below.  It should have everything that you need to pull that puppy off.
When you open the pictures, right click with the mouse and use the save as command to save the picture to your hard drive.
95 steering link
Hey AZ 71,,that is awsome! thanks lots, but only one slight problem. When I save the pics I can not read them. They are too small or the resolution? Are these for a 95 Model year??
Know any way to get the pics bigger and clearer?
                                                Mike
Mike,
They are the ones for the 95.
PM me with your e-mail address and I'll send them to you.  On my machine they open to about 8.5x11 and are clear enough to read.
Thanks AZ, got the pics fine. I also bought a Haynes manual but it did not have as much as I would like.
Anyway I started taking the column apart today..what a chore. I got the air bag and horn pad off, and the steering wheel off after borrowing a puller. Then the fun part! To get the air bag coil off it looks like I would have to take off the upper and lower colunm covers that wrap around the top of the column. Well thats not good because it also looks like I have to take my lower console down  to get that bottom cover off.....what a bummer. And I have no instructions on how to do it so I just put it back together.
If anyone has had any experience with this please forward....Mike
    Brendan C
    Brendan C
  • Who's Online   3 Members, 0 Anonymous, 1,049 Guests (See full list)
