4L60E R&R DIY websites/write-ups ref?
I'm looking too.  Just ordered a tranny manual and rebuild video for my 4l60e.  Gonna look at those before deciding if I want to tckle it myself.  Any other info would be helpful too.
does this help?
Document ID # 744076
2002 Chevrolet Chevy C Silverado - 2WD
Transmission Replacement
Tools Required
J 21366 Converter Holding Strap
Removal Procedure
Disconnect the battery.
Raise the vehicle. Refer to Lifting and Jacking the Vehicle in General Information.
Drain the transmission fluid. Refer to Automatic Transmission Fluid/Filter Replacement .
Remove the rear propeller shaft. Refer to Propeller Shaft Replacement - Two Piece or Propeller Shaft Replacement - One Piece in Propeller Shaft.
Support the transmission with a transmission jack.
Remove the nut securing the transmission mount to the transmission support.
Remove the nuts and bolts securing the transmission support to the frame.
Raise the transmission slightly and remove the transmission support from the vehicle.
Remove the exhaust pipe assembly. Refer to Exhaust Manifold Pipe Replacement in Engine Exhaust.
Remove the starter motor. Refer to Starter Motor Replacement in Engine Electrical.
If the vehicle is equipped with a transfer case, remove the front propeller shaft. Refer to Propeller Shaft Replacement - Front in Driveline/Axle.
Lower the transmission to gain access to the top and sides of the transmission.
Disconnect the vent tube hose and the electrical connections from the transfer case, if equipped.
Remove the transmission mount.
Remove the transfer case, if equipped. Refer to the appropriate procedure:
Transfer Case Assembly Replacement in Transfer Case - NVG 261-NP2
Transfer Case Assembly Replacement in Transfer Case - NVG 149-NP
Transfer Case Assembly Replacement in Transfer Case - NVG 263-NP1
Remove the shift cable end from the transmission shift lever ball stud and the pan rail bracket. Refer to Automatic Transmission Range Selector Cable Replacement .
Remove the transmission heat shield.
Disconnect the transmission vent hose, the park/neutral position switch connector, and the main electrical connector from the transmission. Refer to Park/Neutral Position Switch Replacement .
Remove the bolt that secures the fuel line bracket to the left side of the transmission.
Remove the torque converter access plug.
Remove the flywheel to torque converter bolts.
Disconnect the transmission oil cooler lines from the transmission. Refer to Transmission Fluid Cooler Hose/Pipe Replacement .
Plug the transmission oil cooler line connectors in the transmission case.
Remove the stud and the bolt securing the transmission to the engine.
Remove the six studs and one bolt securing the transmission to the engine.
Install the J 21366 onto the transmission bell housing to retain the torque converter.
Pull the transmission straight back.
Remove the transmission from the vehicle while simultaneously removing the fluid level indicator tube.
Installation Procedure
Raise the transmission into place while simultaneously installing the fluid indicator tube.
Remove the J 21366 from the transmission.
Slide the transmission straight onto the locating pins while lining up the marks on the flywheel and the torque converter. The torque converter must rotate freely by hand.
Notice
Use the correct fastener in the correct location. Replacement fasteners must be the correct part number for that application. Fasteners requiring replacement or fasteners requiring the use of thread locking compound or sealant are identified in the service procedure. Do not use paints, lubricants, or corrosion inhibitors on fasteners or fastener joint surfaces unless specified. These coatings affect fastener torque and joint clamping force and may damage the fastener. Use the correct tightening sequence and specifications when installing fasteners in order to avoid damage to parts and systems.
Install six studs and one bolt securing the transmission to the engine. Tighten
Tighten the studs and the bolt to 50 N·m (37 lb ft).
Install the stud and bolt securing the transmission to the engine. Tighten
Tighten the stud and the bolt to 50 N·m (37 lb ft).
Install the flywheel to torque converter bolts. Tighten
Tighten the bolts to 63 N·m (46 lb ft).
Install the torque converter access plug.
Install the transmission vent hose, fuel lines, and the wiring harness to the transmission.
Install the two bolts securing the heat shield to the transmission. Tighten
Tighten the bolt to 17 N·m (13 lb ft).
Install the shift cable to the shift lever ball stud and the bracket. Refer to Automatic Transmission Range Selector Cable Replacement .
Install the transfer case, if equipped. Refer to the appropriate procedure:
Install the two bolts and nut securing the transmission rear mount to the transmission. Tighten
Tighten the bolts and nut to 25 N·m (18 lb ft).
Connect the vent hose and electrical connectors to the transfer case, if equipped.
If the vehicle is equipped with a transfer case, install the front propeller shaft. Refer to Propeller Shaft Replacement - Front in Driveline/Axle.
Install the starter motor. Refer to Starter Motor Replacement in Engine Electrical.
Install the exhaust pipe assembly. Refer to Exhaust Manifold Pipe Replacement in Engine Exhaust.
Install the transmission support to the vehicle. Tighten
Tighten the bolts to 70 N·m (50 lb ft).
Install the transmission mount to transmission support nut. Tighten
Tighten the nuts to 40 N·m (29 lb ft).
Remove the transmission jack.
Install the rear propeller shaft. Refer to Propeller Shaft Replacement - Two Piece or Propeller Shaft Replacement - One Piece in Propeller Shaft.
Flush the transmission oil cooler and cooling lines if necessary.
Connect the oil cooler lines to the transmission. Refer to Transmission Fluid Cooler Hose/Pipe Replacement .
Lower the vehicle.
Connect the battery.
Fill the transmission to the proper level with DEXRON® III transmission fluid. Refer to Transmission Fluid Checking Procedure .
© Copyright General Motors Corporation. All Rights Reserved.
:jester:
Thanks!
I received my ATSG 4L60E Repair/Rebuild manual.  Pretty much read the whole thing.  I am convinced I have a chance of completing it myself as it is pretty thorough.  I should get a rebuild video next week.  After I watch that I will have a good enough idea of the level of complexity to determine if I want to attempt or not.
Parts are reasonably cheap if you don't mind doing the labor.  I figure I'll spend around $500-$600 on parts including some upgrades and a week off work to do it if I decide to forge ahead.
BTW- Manual was $20.  Can get through JCWhitney or http://atsgmiami.com/
Just watched the rebuild video (got it from KDSPerformance).
After watching it, I am definitely going to try it myself.  For me it's not so much the $$ as I actually enjoy taking stuff apart.  I have always been timid about trannies but after watching this I'm gonna crack into it.  Plan on getting all beefed up parts for end of Jan and take a few days off in Feb to rebuild.
See if I have the same opinion after finishing it  :jester:
Bish
    BigJake
    BigJake
  • Who's Online   4 Members, 0 Anonymous, 580 Guests (See full list)
