Tempature issue with 04 Sierra
Ok well I'm new to the forum so I want to first say, hi my name is Nick and I'm glad I found a good forum! I have 2 GMC turck's. Both 04's one HD2500 and one Sierra. The problem I'm having is with the Sierra, it has the 4.8 and is 4wd. I replaced the thermostat about 2 weeks ago and ever since my temp gauge goes crazy. I live in Maine and its cold..real cold. So normal day with the truck now is I go out start it and leave after about 2 mins of solid warm up time. After about 3 mins of driving the temp guage is 3/4 of the way to hot but I know the engine isn't warm enough yet to be that high. Right after the gauge creeps over the 3/4's mark the heat will be warm and it seems as though if I am giving the truck gas it will stay warm but as soon as I slow down the engine the heat goes cold. Also after the heat gets to the 3/4's mark and is warm if I shut the heat off the temp gauge goes to 210 which is normal or where it has been since day one. I didn't bleed the system of air when I changed the thermostat but from what I saw on this forum you dont have to? When changing the themorstat the housing broke so I had to go to the dealer and get a new housing which was deffrent then the original housing it also came with the thermostat and bolted up fine and doesnt leak. I don't think I got the wrong thermostat from the dealer. Maybe the thermostat is bad or there's air in the sytem or the water pump is shot. I don't know what to do..I dont feel like removing the thermostat again if i dont have too. Any advise would be helpful and much appreciated. Thanks! I'm uploading some pics now of the old girls.
Is your coolant level low? Any wet spots on the ground/snow u park on? Sounds like you either have low coolant which would be bad water pump diaphram or air in the system.
The antifreeze level seems to be fine. I really think it's air in the system. What my next question would be is where are the bleeders located if any? Also if I have to bleed it I just jack up the front of the truck and take the radiator cap off and let the truck idle until it opens the thermostat and the air should come out right? Thanks for the quick reply. I'm going out of my head trying to figure this out, it's my wifes truck and I just dont want her to break down or start warping blocks due to heat ect...but at the same time I refuse to take it to a dealer they have caused me enough issues. I'm pretty mechanically inclined, I have a 92 3000gt VR4 TT that I do all the services on ect...
Yeah your idea of bleeding it should work AFAIK. I haven't done this on my truck so I don't know forsure. You might be able to get away with just opening the coolant tank lid (don't have to jack it up) since I think it is pressurized, and higher than the radiator, on those models.
Once you think you have all of the air out, you should keep a close eye on the coolant level for a few days to make sure you arent losing more.
    • New member here, very long time occasional guest. Saw this thread, thought it would be a good time to contribute someting. It is only my experience and not a claim that everyone will have the same.   I bought my '20 3500 L5P new and have put 99.9% (literally) of it's current ~400k miles on it myself, with over 50% of that towing loads between 4k to 15k, and to me this truck has been nothing short of amazing. For the first 235k I had zero issues, and from there until 321k I replaced a NOx sensor, two failing glow plugs, and three of the notorious injector connectors. I believe this truck is in part, a testament to good luck, but also good care and following a decent maintenance schedule (I also keep meticulous records.) As a result, it looks as good as a well cared for 70k rig, up and down, inside and out.   At some point before that 321k mile mark I began to get a little spooked about the 10L1000, especially the valve body. Word of mouth about potential issues prompted me to jump on the net to sift through all the noise and determine what all the fuss was about. I routinely take long trips, coast-to-coast and points in between, so roadside breakdowns can be '...a thousand miles from nowhere' and a bit of a challenge, and though I had no issues, my guard was up and activated.   And then I stumbled across a chance to salvage some parts off a new 2025 that had been wrecked in transport. I grabbed a few wear items (alternator, pulleys, etc.) and on a whim asked what the ten speeder would cost me. It was cheap...really cheap. I knew some changes had been made in the '24+ version 10L and were supposedly not compatible, but I called service/parts at my local Chevy dealer and asked why and they didn't know. A call to a well known aftermarket transmission outfit revealed it was very likely it would be fine, but to them not 100% sure.   Because it was cheap (really cheap) and I was spooked, I took the chance. Had it installed by a local shop and it worked like a champ, shifted just like the original. At it's first service at 37k, I had the shop put in a Next Gen valve body kit, which after some initial hiccups and rough shifts, smoothed out though with somewhat firmer shifting.   All that said, I have a very serious concern about my newer transmission as just two weeks ago it suddenly began to exhibit a strong reluctance to engage forward or reverse. It was a bit past due anyway so I took it in for service. The reason it was sticking was due to 'glitter' in the fluid clogging the filter...not good folks, often indicates a converter giving out. We ended up going ahead with the new filter and fluid, first to see if it would move and shift, and then if so buy me a little time. It did, and I've driven it over a thousand miles and it is shifting smooth, no noises or slipping. Regardless, it looks like a third gearbox is in my future so I can resume taking long trips with some confidence. In the very short term, my curiosity will have me examining the fluid to check how much glitter has reappeared.   An earlier poster had alleged, in the context of 10L100 failures, that it is another example of how we seasoned citizens somehow descend into hysteria, lose control of our senses, and react irrationally after brief encounters with the idiocy of the internet infosphere. Let me say (and I have used and abused said internet since it's infancy) there is no segment of the populace that has a corner on over-reaction to digital garbage. Just as my offering of experience in this arena is purely anecdotal and should not be considered gospel or all-encompassing, I believe it is still worthwhile information to consider, along with other relevant anecdotal experiences about things like complex transmissions, especially when balanced with other sources.   So to answer the original question, yes I got high miles out of my first 10L, trouble free for 321,000. Now I really wonder how much longer it would have went. Did I 'overreact' to the internet ghouls by replacing a 'good' one with a 'bad' one? Maybe. Who knows, the thing might have taken a puke a 100 miles later. So I'll just fix it again, then move on and start thinking about all the other stuff that will eventually wear out. It still has the original brakes (they're at ~60%), original injectors/pump, turbo, water pump, etc....pretty much original everything. Knock on wood.
