I have a 2006 silverado 1500HD LT. As of last night, my driver seat is dead. None of the power seat buttons works. I can't move the seat as well as the heated seat is not working either. All of these features are working on the passenger side. I checked all of the connections on the bottom of the seat and nothing seems loose. I also looked in the manual to see which fuses may be the problem. It looks like there is a fuse that controls the heated seats/Ignition and then a circuit breaker that controls both of the power seats. I have yet to find a fuse that controls JUST the driver seat. So does anyone have any ideas on what else to check or any clues as to why just the driver seat is not working??
So I went ahead and pulled the circuit breaker for several minutes, and put another new 10A fuse in for the power seat and now everything seems to be working......weird. The other fuse that was in there was a good fuse, and it is weird that pulling the circuit breaker for several minutes would fix it, because there are only 2 prongs on the breaker and it controls both seats. I never had any trouble with the passenger seat. Do I have an electrical Gremlin??!!!
Your driver's motor was jammed somehow and needed a reset by removing and reapplying power. How often do you actually move it? The only time I move my Malibu's power seat is to clean under it.
I rarely ever move the seat or adjust it. I have been using the heated seats daily...I live in Alaska. But they appear to be 2 complete different circuits because the power to the seat is the 30A circuit breaker that controls both seats and then the heated seats are included in the ignition with a 10A fuse. So I just think it is odd that they both go out at the same time and that it was only the driver side and not the passenger.
I do have one motor that has stopped worrking, it is the front tilt motor on the bottom cushion. It stopped working a while back.
I'm make some (educated) assumptions here, but it would explain what you found:
*the fuse you are referring to, the 10a one: I can promise that 10a is not enough current to power a seat heater, most likely that fuse only powers the control circuit to the seat heater. It carries small amounts of power to activate a relay under the seat that turns on the seat heater
*the breaker you pulled: it supplies all of the power to the seat motors and seat heaters, that's why it's 30a. ALSO, an automotive circuit breaker is designed to "trip" and stay in that state until power is removed, then it will reset itself and continue to function as long as power isn't overdrawn. This is unlike your house breakers that you go and turn off then back on, there is no switch on the automotive version.
Some basic electrical to further explain:
Switches rarely carry the full load of the item it is switching, it minimizes wiring size, weight and routing high amperage capability where it's not needed (no need for that much power to go in to your door panel control bank in the first place if it's coming back out). Instead millivolts are passed through the switch and those millivolts activate a relay that switches the big power.
I have no idea why the other seat was still working unless you are mistaken and there is a separate breaker, I just don't know.
Got in my truck this morning and there is no heat in the seats, and the power on the driver has stopped working. If it is a relay setup, where is the relay for the seats, and where is the fuse that controls the other side of the relay??
the relays are under the seat. The seat has only one power wire feeding it, it gets distributed under the seat.
There is no fuse on the power to the relay, that's what the circuit breaker is for. Pull the breaker and reinstall it and you should have power again. Chances are you have a short somewhere under your seat and it's tripping the breaker. Could be a bad wire, seat motor or seat heater.
Sounds like a lot of fun is in my future.......I tried pulling the circuit breaker again and leaving it out for a little bit and then reinstalling, and that didnt help it this time. Am I correct in assuming that the heated seats and power function are on 2 seperate circuits since they are in 2 seperate locations on the fuse block?? If so, any ideas why they would both quit working at the same time, or is it just a fluke and I really have 2 seperate issues that just happened to occur at the same time??
  • 4 years later...
  • 8 months later...
  • 11 months later...
Hey Guys, my 2003 Suburban's power driver's seat worked when the wife took it to the store, but when I went out later the seat was dead. No power, and the heater was a zero as well... Passenger seat was still functioning fine... ...I disconnected the battery for 30 seconds, and after reconnecting, the seat works again. Give it a shot...can't hurt...hope this helps somebody.
  • 1 year later...
Did this fix the problem, or did it persist down the road?
  • 2 months later...
    Whit.the.COB
    Whit.the.COB
  • Who's Online   2 Members, 0 Anonymous, 1,254 Guests (See full list)
    • Yep! This should be a pin somewhere as @pgamboa really dives into all of this. Thanks for reposting the link!
    • I did the new thermostat after doing a 'flip' for a year. Runs as cool one way as the other in the summer but in the winter there is a bit of a floor. Yellow with the new 70 C thermostat. My data over the life of the unit to date. Still need more cooler. Anyway that floor helped both winter fuel economy and shift quality in the winter. I found it a good balance.
    • Evan Williams Bottled in Bond   So pouring the last of a bottle of Evan Williams Black label last night I set off the the state store for a refill only to be denied the by an empty shelf. Rats.    What the did have was a bottle of Evan Williams Bottled in Bond. 100 proof. Hum, a few bucks more but a known distiller. Lets have a swing at it. ( I have before )    Cracked it open and pour a serving over ice. Hum.... more heat, yes. More alcohol naturally. But the barreling not the proof brings the taste and this one came up short.    Oh is was familiar but the heat ran the barrel over like a Peterbilt runs over a squirrel. Could use a heavier toasting of the oak me thinks or perhaps a longer barreling. Who knows. But what I can say is ice or a water back isn't the answer. What kills one kills them both. Sad. It is a pleasant drink....if you have little to compare it to.
    • I've had exactly one set of Bridgestone. Lasted five year and 125,000 miles and had I known better 15oK would have been a cake walk. I would have bought a like set had they not tripled in price since the first set. I removed them at said mileage with 5/32" remaining in dead even wear all four. They were fuel efficient, quite, comfortable and predictable.    Early on I got a very good alignment checked at least once a year, sometimes twice; kept the tires properly inflated, balanced and rotated. And I've found that many a tire issue can be avoided with great maintenance practices. Lot's of tire dealers will do rotation and balance (simple) for free for as long as you own the tire they sold you so no excuse not to.    Bead prep, alloy integrity and stem health have a huge impact on inflation stability. There are more mountings done poorly that perfectly. Finding a good tire guy is gold and as important as finding a tire you like.    That 3X price increase now two sets of "other tires' later is starting look like a bargain.      Bad maintenance kills more tires than bad tires.
    • Atlas, you kill me As aggravating as a project like this can be you have been unable to hide your fascination with learning and using that angst against this beast like a Ninjitsu Master. It amuses you, admit it now.      BTW, love your writing style. 😉
