I have a 2006 silverado 1500HD LT. As of last night, my driver seat is dead. None of the power seat buttons works. I can't move the seat as well as the heated seat is not working either. All of these features are working on the passenger side. I checked all of the connections on the bottom of the seat and nothing seems loose. I also looked in the manual to see which fuses may be the problem. It looks like there is a fuse that controls the heated seats/Ignition and then a circuit breaker that controls both of the power seats. I have yet to find a fuse that controls JUST the driver seat. So does anyone have any ideas on what else to check or any clues as to why just the driver seat is not working??
So I went ahead and pulled the circuit breaker for several minutes, and put another new 10A fuse in for the power seat and now everything seems to be working......weird. The other fuse that was in there was a good fuse, and it is weird that pulling the circuit breaker for several minutes would fix it, because there are only 2 prongs on the breaker and it controls both seats. I never had any trouble with the passenger seat. Do I have an electrical Gremlin??!!!
Your driver's motor was jammed somehow and needed a reset by removing and reapplying power. How often do you actually move it? The only time I move my Malibu's power seat is to clean under it.
I rarely ever move the seat or adjust it. I have been using the heated seats daily...I live in Alaska. But they appear to be 2 complete different circuits because the power to the seat is the 30A circuit breaker that controls both seats and then the heated seats are included in the ignition with a 10A fuse. So I just think it is odd that they both go out at the same time and that it was only the driver side and not the passenger.
I do have one motor that has stopped worrking, it is the front tilt motor on the bottom cushion. It stopped working a while back.
I'm make some (educated) assumptions here, but it would explain what you found:
*the fuse you are referring to, the 10a one: I can promise that 10a is not enough current to power a seat heater, most likely that fuse only powers the control circuit to the seat heater. It carries small amounts of power to activate a relay under the seat that turns on the seat heater
*the breaker you pulled: it supplies all of the power to the seat motors and seat heaters, that's why it's 30a. ALSO, an automotive circuit breaker is designed to "trip" and stay in that state until power is removed, then it will reset itself and continue to function as long as power isn't overdrawn. This is unlike your house breakers that you go and turn off then back on, there is no switch on the automotive version.
Some basic electrical to further explain:
Switches rarely carry the full load of the item it is switching, it minimizes wiring size, weight and routing high amperage capability where it's not needed (no need for that much power to go in to your door panel control bank in the first place if it's coming back out). Instead millivolts are passed through the switch and those millivolts activate a relay that switches the big power.
I have no idea why the other seat was still working unless you are mistaken and there is a separate breaker, I just don't know.
Got in my truck this morning and there is no heat in the seats, and the power on the driver has stopped working. If it is a relay setup, where is the relay for the seats, and where is the fuse that controls the other side of the relay??
the relays are under the seat. The seat has only one power wire feeding it, it gets distributed under the seat.
There is no fuse on the power to the relay, that's what the circuit breaker is for. Pull the breaker and reinstall it and you should have power again. Chances are you have a short somewhere under your seat and it's tripping the breaker. Could be a bad wire, seat motor or seat heater.
Sounds like a lot of fun is in my future.......I tried pulling the circuit breaker again and leaving it out for a little bit and then reinstalling, and that didnt help it this time. Am I correct in assuming that the heated seats and power function are on 2 seperate circuits since they are in 2 seperate locations on the fuse block?? If so, any ideas why they would both quit working at the same time, or is it just a fluke and I really have 2 seperate issues that just happened to occur at the same time??
  • 4 years later...
  • 8 months later...
  • 11 months later...
Hey Guys, my 2003 Suburban's power driver's seat worked when the wife took it to the store, but when I went out later the seat was dead. No power, and the heater was a zero as well... Passenger seat was still functioning fine... ...I disconnected the battery for 30 seconds, and after reconnecting, the seat works again. Give it a shot...can't hurt...hope this helps somebody.
Did this fix the problem, or did it persist down the road?
    btm
    btm
  • Who's Online   1 Member, 0 Anonymous, 1,298 Guests (See full list)
    • Can ask that about a lot of places.   Holiday sells 91 for $1 over 87 octane. BP 93 is 80 cents. Amoco 93 is 80 cents Kwik Trips is $1.20 for 92 or whatever they have and $1 for the 91.   I know that this is not exactly same as what you are saying with the premium to premium debate of those two stations but why is there such a difference. Top Tier this and that, it's all BS. All the fuel comes from the same damn refinery, so give me a break.
    • Why does Mobil Premium cost 90 cents a gallon more than Shell Premium when their regular offerings are but pennies apart?
    • Was all the way down to $3.69 a gallon but then jumped back to $3.99 just because for some reason.   Diesel floats between $4.80's to $5.10ish a gallon. I even saw Diesel #1 for $6.09 today but nobody in there right mind even buys that in the summer.
    • Mine just keeps lagging or getting stuck on the reverse camera. When I turn off the truck, get out, and close the door it will still stay on. It’s very intermittent and I would not be able to duplicate the issue.
    • I was checking out fuel prices at my farm fuel retailer at their pumps and yes the farm price is a bit lower than the non dyed fuel and was glad to see that the regular farm gas price has dropped a lot from what it had been but what blew me away was the price of diesel as the spread now compared to before the prices went up earlier in the year, diesel was actually slightly lower than gas which was a switch from the theme the last number of years. However that sure isn't the theme lately and definitely not right now. The prices I will post are not from that retailer but just looking at gasbuddy for the main city in this area and instead of posting the lowest price someone found I will list the higher price ( and that may not be the highest price, just whatever someone posted on gasbuddy ).   So regular gas and there are a lot of stations listing the same price for regular is 1.68 a liter, premium 2.00 a liter. Diesel 2.03 a liter for a top price I saw on diesel.   Figures out to 6.36 a us gallon Canadian funds for regular and 7.68 for diesel. With the US exchange rate it would be 4.58 us for regular and 5.53 for diesel.    Thought I would figure that out to get a picture of what it settles out like compared to various US prices and its about the same as the current price in Fairbanks AK as Anchorage tends to be lower. So yes, these would be the prices and higher along the way on the Alaska highway where they know they have a captured market !, for fuel prices for those beginning the long drive back to the lower 48   The problem is our Canadian dollar and going to the states that have the high prices, boy do we pay then !
