Lets see photos of those Plows and trucks.
2010LTZ4x4
I'll start, I use mine only on my property its far from being road worthy but it works well and the heat and 4x4 works,thats important.
1987 fullsize GMC Jimmy
TBI 350 w/ 700R4 tranny and solid front axle.
Added a leaf up front for the plow.
7' Poly Meyers Plow with Joy Stick Control
What I used to have, I traded the plow with the truck and kinda regret it.
This was on ebay not too long ago, who says nnbs can't plow?
Don't see too many Colorados with plows. I like it.
The Colorado would be an excellent residential plow truck being so short and narrow. Kinda like my Jimmy and I don't need a football feild to turn it around :driving:
The nnbs looks like it needs more help up front with the extra weight of that plow.
I would say a little bit of ballast and Timbrens in front should be good to go. If it were mine thats what I would have done and take it right off after plowing.
Here's my 91 S-15 Jimmy. Heat stopped working last winter, as well as the wipers, but it's better than nothing for doing just my driveway.
--JOsh
    ChristopherDobson
    ChristopherDobson
  • Who's Online   0 Members, 0 Anonymous, 1,228 Guests (See full list)
    • Thanks newdude!  By the time manual selection is needed, I'm probably too much of a control-freak to depend on the transmission sensing braking to activate automatic downshifting.  I would be anticipating the situation and already be manually downshifting.   This truck replaced a 2004.5 LLY diesel with the Allison 5-speed.  Putting it in T/H made noticeable differences (when the torque converter locked, upshift points, downshift behavior).  On this 2024 gasser with the 10L1000 I haven't been able to detect much, if any, difference.  Ok, I can never tell now when the torque converter locks up.  But I also don't notice differences in shifting.  For downhills, I've probably already manually downshifted by then anyway.  Since it's also more awkward (than the 2004.5) to engage/disengage I don't even bother.  Or maybe it doesn't really matter with just a 3k lb. camper in the bed?   Thanks also for the list of reasons the charging system might select various voltages.  However, what I am seeing doesn't fall into any of those categories.  It very definitely, and very consistently, rises after coasting/braking.  Maybe not immediately, but not very long after coasting/braking.  Very consistently drops voltage when no longer coasting/braking.  It might also be interacting with the camper battery charging (I might disconnect the camper and see if it changes the charging behavior).  I also need to recheck turning on headlights for when I want to force it to charge the camper.   Another JR, in June I converted the camper to LiFePO4.  Since it's not a good idea to try to charge lithiums directly using truck, I installed a Victron Orion XS DC-DC charger (which BTW is AMAZING!!).  Being cheap, I only had to buy that one item (besides the battery, of course) to do the conversion.  The camper OEM 120v battery charger (only 19 years old and works perfectly) and the truck feed the input to the DC-DC charger (not at the same time).  But I didn't want the camper charger feeding back to the truck so I kept the old separator.  I considered replacing the separator with a 30amp diode but that means more work and might add another 1/2 volt drop.  One thing that surprised me was the voltage drop over the long 10awg wire run, so I can only charge smoothly at 8 amps (because the DC-DC charger is completely configurable).  Another reason I don't want an added voltage drop with the diode.  I might also be a little lazy but all this work is being done under the sink with a small cabinet opening.
