No right side power windows
formerlylifted
Ok, here's the deal: My right side power windows stopped working. I replaced the MBEC-1 fuse wich had blown. It happened several times so (like a bonehead), I crossed the fuse connectors to avoid buying more fuses :) . As we all know, it worked-until it didn't anymore. I replaced the fuse with a good one and it no longer blows, but windows still didn't work. I did some digging and found "circuit breaker 1" (CB1 under the dash, between the e-brake and brake pedals) was bad. Replaced it and the widows worked again for a little bit. The dinger went off and my air bag light flashed 3 times. I could hear the cb1 tripping so I pulled it. Now, if I try to put it back in, it immediately starts tripping over and over and arcs the terminals. I pulled the door panels and looked over the wires under the dash but none appear to be missing any insulation. Is there any certain place I should be looking?
    rayredbone
    rayredbone
  • Who's Online   0 Members, 0 Anonymous, 504 Guests (See full list)
    • Thank You.   So far my new ride is making me look like a genius for going with the 3.0L, as my first fuel refill occurred over three weeks from when I took delivery.  This engine combination is very amazing.  So far no issues and had not done a regen yet.
    • I am curious as to how much fluid you put back in the transmission ( assuming you had replaced the filter to compare to my findings ) and then went through the process of warming up the trans before pulling the check plug to drain out the excess and if you measured how much came back out.    I just found it surprising that some claimed a certain amount less fluid being put in and then draining some back out. The attitude of the truck as per if the surface is level and how the trucks stance is would make quite a difference since the check plug is right at the front of the transmission.
