Which Spark Plug Wires?
animlmed
I replaced my spark plugs about 10,000 miles ago with AC Delco Iridium, but I figured replacing the wires couldn't hurt (even though nothing was knowingly wrong with the current wires at the current 125,000 miles). I ordered the wires based on the specific coil (Melco)I have on my 2005 1500 Sierra Z71 5.3L . I replaced my original wires with AC Delco 9748HH wires (http://www.amazon.co...e/dp/B000S2QVYE).
Here are my questions:
1. Are these the correct wires? The Delco site lists these and another set of wires without a 9 in front of the product number (9748HH versus 748HH). The only difference I can tell is that the 9 indicates they are the "Pro" series.
2. Is there a specific order they should be used? I noticed that on both the boot end and the coil end they are stamped with different "Kw" numbers. I assume these reference a specific resistance, but I am not sure.
I ask because I installed the wires on my truck without obvious issue and everything seemed to be working correctly; however, my gas mileage decreased after installing (17 to 18 on the highway down to 14 or 15). Over the weekend I put the original wires back on the the truck and the gas mileage has gone back up. I only had the new wires on for approximately a week, so my observation time was small. However, I went through two different tanks of gas with the same low mileage results.
Any help you may be able to offer or help pointing out any obvious flaw would be most appreciated.
Thank you!!!
Alex
  • 4 weeks later...
i will say that I replaced my plugs and wires just as you did on my 05 Sierra this past summer/fall. I didn't check my mileage immediately prior or immediately after, but I did get 24 easily as recently 6 months before the tune up. I did the tune up and checked mileage just recently...I lost 10% mpg easily, maybe more. Wish I had kept the old wire set to try them back. FWIW, I got my wires from amazon as well and they were Delco as well
  • 1 month later...
Hmm that's interesting that they are both from Amazon. I thought about buying another pair from Discount auto parts or something to see if I had the same results. I still have the box for mine so perhaps I will see if Amazon will take them back. Of course, there is no guarantee that the other plugs will act any differently.
    Whit.the.COB
    Whit.the.COB
  • Who's Online   2 Members, 0 Anonymous, 1,039 Guests (See full list)
    • Even tougher is the 5.0 / 302. That's what this one has.    https://postimg.cc/Z9XRrCSg   https://postimg.cc/4n3F3yzY   Just realized I had the airbox removed in the engine pic, lol.
    • Yep! This should be a pin somewhere as @pgamboa really dives into all of this. Thanks for reposting the link!
    • I did the new thermostat after doing a 'flip' for a year. Runs as cool one way as the other in the summer but in the winter there is a bit of a floor. Yellow with the new 70 C thermostat. My data over the life of the unit to date. Still need more cooler. Anyway that floor helped both winter fuel economy and shift quality in the winter. I found it a good balance.
    • Evan Williams Bottled in Bond   So pouring the last of a bottle of Evan Williams Black label last night I set off the the state store for a refill only to be denied the by an empty shelf. Rats.    What the did have was a bottle of Evan Williams Bottled in Bond. 100 proof. Hum, a few bucks more but a known distiller. Lets have a swing at it. ( I have before )    Cracked it open and pour a serving over ice. Hum.... more heat, yes. More alcohol naturally. But the barreling not the proof brings the taste and this one came up short.    Oh is was familiar but the heat ran the barrel over like a Peterbilt runs over a squirrel. Could use a heavier toasting of the oak me thinks or perhaps a longer barreling. Who knows. But what I can say is ice or a water back isn't the answer. What kills one kills them both. Sad. It is a pleasant drink....if you have little to compare it to.
    • I've had exactly one set of Bridgestone. Lasted five year and 125,000 miles and had I known better 15oK would have been a cake walk. I would have bought a like set had they not tripled in price since the first set. I removed them at said mileage with 5/32" remaining in dead even wear all four. They were fuel efficient, quite, comfortable and predictable.    Early on I got a very good alignment checked at least once a year, sometimes twice; kept the tires properly inflated, balanced and rotated. And I've found that many a tire issue can be avoided with great maintenance practices. Lot's of tire dealers will do rotation and balance (simple) for free for as long as you own the tire they sold you so no excuse not to.    Bead prep, alloy integrity and stem health have a huge impact on inflation stability. There are more mountings done poorly that perfectly. Finding a good tire guy is gold and as important as finding a tire you like.    That 3X price increase now two sets of "other tires' later is starting look like a bargain.      Bad maintenance kills more tires than bad tires.
