Quick confirmation door handles
I wanted to confirm that door.handles from a 2009-2011 1500 will work on a 2011 2500. Wanted to confirm before I bought.
Thanks
yes
if you are buying colored handles be careful as in 09 there was a different silver color than 10-11 MY's. Also some of the Gray colors are different too.
    Brendan C
    Brendan C
  • Who's Online   1 Member, 0 Anonymous, 1,065 Guests (See full list)
