Time Delay Relay for HIDs...Options
Knowklew
So I have been looking for a time delay 12v SPDT automotive relay for my HID relay harness.
I have projector headlight housings with HIDs in them and I love the look plus I dont blind everyone like the stock housings with HIDs
The problem I have is that when I start the truck at night the ballasts will fire then go off because of the drop in voltage from starting the truck. I have to then manually turn the headlights on.
I know the bike guys use time delay setups for their HID setups but I cannot find a time delay relay.
Thanks,
Fred
I turned off approach lighting as well, but when i remote start the truck at night or just get in and start at night, the automatic headlights will turn the lights on.
I am considering disabling my automatic headlights...
if you wire the hids direct to the battery you shouldnt encounter the ballast flickering. That worked for mine.
  • 4 weeks later...
My HID's are wired using a relay harness that takes power directly from the battery...
