cruise control on 2011 sierra
When I set the cruise on my sierra it works just fine. My question is about increasing the cruise speed. I can use the accel button at the top, but that ussually makes the truck downshift and such, it is just a bit 'dramatic'.
If I increase my speed with the pedal then hit the 'set' button the truck falls back to the previous speed. It seems I have to kick off the cruise, increase my speed with the pedal and then reset the cruise.
Does this seem correct??
Hud
Yup!, now i just use my accel button but i tap it and dont hold it down
Agree^. Just tap it and take your time between taps. Each tap I think increases by 1 mph. Every vehicle I've owned reacts this way and downshifts.
Hud
Yes I noticed this and a first thought there was a problem. Turns out the only problem is that is normal operation. Another weird quirk of operation to get used to.....
I am prety sure the SET button is also the - button, so once cruise is it and the SET button is pressed it actually decreases speed?
I tested it on my Silverado and unless there is something different between Chevy and GMC you should be able to use the accelerator pedal to speed up and then hit the SET button to set the new speed.
^ That the way it works on mine, I guess they changed it on the 900s. All I do is hold it for a second or two and it locks to the current speed.
Turns out that holding down SET will make it register the new speed.
Tryed it today, took 2 trys but holding set will work,the light of the dash will turn off then back on, then you know its set
    appletrav
    appletrav
  • Who's Online   0 Members, 0 Anonymous, 279 Guests (See full list)
