If anyone needed proof about the BIG 3
I decided to do a little test to see if this was really worth it..... I did 2 of the big 3, leaving out the negative to chassis upgrade. I tested power at the cable ends before they went into the amp... 12.5 V. Then i added the negative to chassis cable. 14.8 V. This is without the subs hitting, the engine on, and I have a yellow top battery. May add a second when i see what it does with 1200w hitting hard.
pics of your big 3 wiring and connectors? installed pics?
I have an install thread going. Im out now but I'll check later and make sure those pics are in there
Ok so I figured I'd take better daylight pics and put them here.
In this first pic you see the top connections to the battery. On the positive terminal I have a JL 3x0 or 4 gauge. Right now one spot is free, one loops around towards you and to the fuse. Then continues to the amp in the back of the truck. The other goes to the alternator. The negative terminal is a kicker 2x 0 or 4 awg. Only one spot is used at the moment. You can see it goes right up to the chassis there. The two empties are to parallel another battery should I need it. In which case I will also use two double set screw set ups and use the free ones for a permanent jumper cable set up.
In this next pic you can see the side terminals, both the same dbl kicker I used on top. I hacked off the factory ends and set them in these.
The next one shows the attachment to the alternator from battery positive on the right with the factory line. On the left and lower is where I put the engine side of the engine to chassis.
Lastly is the chassis side of the engine to chassis. I simply connected it with the existing ground. Also you can see the positive to the amps shooting down, it goes through the firewall below the brake booster.
Also this is all 0awg. When the amp line gets to the back it splits to 2 x 4 awg.
Great pics, thank you.
Where did you get all your cables and connectors?
    RichardRS
    RichardRS
  • Who's Online   1 Member, 0 Anonymous, 657 Guests (See full list)
    • Well that book won't sell many copies. Taking ones right foot off the loud pedal never gets applause. Funny really, It isn't that people don't know what to do...they just don't want to do it. But they will complain about it. About bad craftsmanship, about the cost of fuel, about the cost of part and repairs and mainly they complain that the solution while still possible isn't one they are willing to do.    I observe this daily. 'Gas cost to much!", they wail, while they mat it passing at 80+ mpg and scoot down the road like gas cost a dime a gallon. Then complain about the few that will lift and save both fuel and iron like they are owed and own the road.    Good thing they haven't an ounce of influence on my equipment. The rest I just laugh at. Stupid is as stupid does, right Forest?
    • Today I filled up with 4.899 gallons of fuel at a cost of $4.899 a gallon. $24 bucks. 290 miles. 59.2 mpg. After my 4% COSTCO discount just under eight cents a mile.
    • Howdy folks,   Recently I pulled a heated steering wheel and clock spring out of a 2015 Sierra All Terrain (part numbers coming soon - will have to disassemble), and just installed it on my 2016 Sierra WT (as base model as it gets).   On install, I noticed that I’m missing the connector often tucked behind the dash for the heating element.     No problem… or so I thought.   I used an “Add-A-Fuse” at my heated steering wheel fuse location, which has voltage, but no wires. I ran it to the positive of the heated steering wheel (Violet/White), and took black to ground.   Hooked up the battery, turned the truck on - no heated steering wheel. No button backlights. Was pleased to see that my cruise control was working though.   Read a post suggesting reversing polarity, so I gave it a shot. Violet and White to ground, Black to power.    Aha! Heat! But I seemingly can’t turn it off AND still no backlights on any of the buttons.    Checked all fuses, everything is still in good order. I’m stumped.   Does anyone have any insight? If so, please share!
    • I'm about 1800 miles into my last oil change, and yesterday a message appeared saying oil life was at 77%. Not sure why it popped up but I think all of these electronics could be susceptible to solar flares or somesuch. I change my oil right at 3K each time, and that was the first time in 10870 miles that message came up. Strange thing is that it showed on the screen at all since I don't drive with that sort of info displayed on the DIC.
    • I’m praying that someone sees this and can help me out… pulled a heated steering wheel and clock spring out of a 2015 Sierra All Terrain, and just installed it on my 2016 Sierra WT (as base model as it gets).   On install, I noticed that I’m missing the connector often tucked behind the dash.     No problem… or so I thought.   I used an “Add-A-Fuse” at my heated steering wheel fuse location, which has voltage, but no wires. I ran it to the positive of the heated steering wheel (Violet/White), and took black to ground.   Hooked up the battery, turned the truck on - no heated steering wheel. No button backlights. Was pleased to see that my cruise control was working though.   Read a post suggesting reversing polarity, so I gave it a shot. Violet and White to ground, Black to power.    Aha! Heat! But can’t turn it off AND still no backlights.   Checked all fuses, everything is still in good order. I’m stumped.   Does anyone have any insight? If so, please share!
