Power seat fore and aft travel reduced
booster
The power seat on my 2005 Suburban has stopped moving thru its full travel fore and aft. It only moves about 4 inches total in travel now. It only moves about 4 inches shy of full forward travel and stops as if it has hit its forward limit. Moving rearward 4 inches the seat stops moving and each time you hit the switch to move the seat rearward the motor will torque each time you hit the switch as if it is attempting to move. The seat will not move even though the motor is torquing. The rest of the seat controls as well as the seat heaters are working as normal.
Unless you already have, I'd take a real good look under your seat for anything that may be holding up the seat. Sounds like something holding up the seat, maybe even along side of seat (snagged) or something in the tracks the seats moves in. Sorry don't have any other suggestions.
I was having problems with mine as well.It would move when it wanted to...I took a chance and sprayed the hell out of the tracks with WD40 and it started working fine.Just a thought.....
    appletrav
    appletrav
  • Who's Online   3 Members, 0 Anonymous, 344 Guests (See full list)
