Climate control.issues 04 sierra manual dual zone
OK so I've done some research. Actuators seem to be fine. Happens is the driver and passenger sides are opposite. No matter what. I move the driver slide down to cold and drover side gets cold. Passenger side gets heat. Move drivers side slide to hot and I get heat and passenger side gets cold. Also a note not sure if relevant but the lights on th control for the passenger slide are out. Could this still be actuators or does it seem like a control unit issue.
Sent from my DROID X2 using Xparent Red Tapatalk 2
Though not sure why your getting oppostie results, but I know it should be the lighting since one side of the slide bar on mine is out, though if I tap it a few time the light will come back on.
i just dont know if it could be an actuator since the passenger side is a slave to the drivers side but acts in opposite
I think each side has its' own actuator. Sounds like the drivers one is working.Passenger one isn't. You don't say what temp you have the passenger side set at when this happens? You move it and nothing happens??
ill have to check that out
i adjusted the passenger side from cold to hot. driver side still set to cold. passenger was hot. dropped passenger side to cold and the controls switched driver was hot passenger cold.
    ballencd
    ballencd
  • Who's Online   5 Members, 1 Anonymous, 654 Guests (See full list)
    • Brought my 2015 Colorado into the dealership to check my touch screen issues, had that ghost touch thing happening. They said I needed a new touch screen and they could either order me one for $500. The lady at the service deck was nice enough to tell me I could order a touch screen online for less, she did stipulate that the touch screen had to be factory OEM, you can't pair an aftermarket screen to my radio seeing it was 2015, it had to be a GM factory OEM only. I found a few on Amazon and Ebay by the numbers on the back of the old screen, DJ080PA-01A GM# 22740886, Some said "OEM" in the description and others just said "Replacement". Would a replacement be the same as a OEM as long as it had the same numbers on the back of the screen? In some of the descriptions they also show different brand names but same numbers, is that an issue?
    • I have both but typically use the 4 legged walker (wheels on front, ski's on back).   The four wheeler is starting to be used on "longer" outdoor walks.  The 4 legged walker is particularly helpful in practicing good walking posture.  Both of my knees are at different stages of recovery and I'm trying to not develop poor habits.  I can actually manage with a cane but it's very difficult not to favor one leg over the other.  My PT recommends I continue with my 4 legged walker for a while.  Yesterday was four weeks since my last knee replacement and I'm excited about my progress to date.  It has been a hell of a rough journey so far but it is exciting to witness  systematic and continuous improvement.  I went for years watching the decline of my "mobility".  It seems that everyday now I am alerting my wife to something I can do now that I couldn't a day or two ago!  I encourage anyone facing the prospect of knee replacement to share any concerns with others who have had the surgery.  It isn't an instant fix but rather is a considerable amount of short term pain for long term gain.  Recovery time and pain levels vary for individuals post surgery but the end results are typically very positive and I've never encountered anyone regretting having had the surgery.
    • The lifter issue can be dealt with by shorter oil changes and quality oil IMO.
    • Got heavy rain, hail and light rain yesterday.
    • I'm putting in an A-pillar pod/gauges, and I'm asking if anybody can identify a (preferably) fuse for a switched power and illumination circuit on the driver's side interior fuse panel. Offhand, everything I checked with a test light was constant-hot, and I'd much rather uses a piggyback fuse. I can certainly find a wire, but I'd rather not half-tap.   Thanks in advance for any help.
