New to the site, got a couple questions
ARedN
I currently have a 2005 chevy silverado z71 with Goodyear Eagle GS 275x55x20's. These are pretty much a street tire, they need replaced. Will 275X60X20 Coopers or Hankooks fit w/o rubbing? If they won't fit w/o rubbing, what do i need to do so that they will. I don't want my truck 7 miles in the air, as i want to be able to get it into my garage w/ 7' doors. If i need a lift, where is a good place online to buy that? I am a diy guy is it hard to put a lift on?
appreciate any help. thanks
Go to www.tirerack.com and enter the tire size and you can view the specs of the particular tire. You can then compare diameter and width to see if there is much of a difference. I have similar size tires on mine, they do rub a little at full lock on the passenger side inner wheel well in the front and on the sway bar but only at full lock. Mine is a 2wd so I don't think you will have a problem.
    ballencd
    ballencd
  • Who's Online   5 Members, 0 Anonymous, 713 Guests (See full list)
    • I’m doing an experiment on a vehicle I don’t have much money in. I’m going by the premise that after they last 100K miles they were no mechanical problems with assembly. Or defects with the parts. With oil changes by the minder for the first 127K miles when I acquired it. I quickly went through low mileage oil changes then settled on 5k oil changes with close to 170K miles on the vehicle currently. I did have the option to turn off the cylinder deactivation. I didn’t on this vehicle because in ECONOMY mode at least half the time. It should be a no brainer frequent oil changes are the key. The manufacturer gets away with the long oil changes with its severe service  maintenance. Just ask them what is normal.
    • $5.19 for regular...
