2005 jimmy p300 code
redneck01
i have an 05 jimmy with 260000 km on it i have owned since new. the sunday just passed i was headding down the hwy at 130 kph and the truck died. i pulled over and looked under the hood to find the air cleaner hose disconected. i tried to restart but nothing it would just turn over, at one point i thought it might start but nothing. towed it home and replaced the coil and distributer cap and rotor and it fired right up. today was the first time i tried to take it to work and as soon as i got on the hwy and it got up to running temp it shut down but not totaly. it wont get up over 80kph and it takes a lonk long time to get there. i got it home and hooked it up to my code reader and mass flow problem came up so i changed the mass air flow censor as well as the ignition modual as well as new set of wires. but it still runns bad and cant revi it up over 3000rpm, even in nuteral. hooked up the code reader again and i get the p300 code for random missfire. also upper and lower rad hose were sucked flat. had to open the rad cap to get them back to a round shape. I have been hard on this truck like everother chev i have and this is the first problem i have had with it. any ideas on what is going on? i am thinking intake gasket but it just stoped running at hwy speeds and i dont think an intake gasket would do that.....
  • Like This
  • Unlike
  • Back to top
  • Quote
  • MultiQuote
  • Edit
  • Report
You need a new radiator cap.
As for the misfire, I parted out a '00 Jimmy that had the same problem. At that point I'd had enough. Check engine lights every week for 2 years straight will do that to ya ... but that random misfire could be anything from the injector spider leaking, or fuel pressure regulator, to leaky intake gaskets, ignition problems, or in rare instances a partially failed crank position sensor.
I took that same engine, removed all electronics, & installed it in a '89 S10 with a carb & HEI ignition - it went from breaking down every week (in the Jimmy) to the most reliable vehicle in my fleet. Better throttle response & performance too. Electronics are wonderful .......... when they're new.
there are no fuel leaks and i tested the intake gasket and it is has no leaks either. i am thinking fuel pump, crank position censor or fuel reg. Also to elaborate on the back ground of the truck.... I live in northern ontario canada and this past winter if i left the truck for more then two days in the cold with out starting it i would have to turn it over for an hour holding the fuel pedel to the floor to ge ti to start. also latley befor the big break down it would have a misfire when started but would go away once it wormed up. i will run the truck with the rad cap loose but right now it is in my garage as i cant drive it at all.... i have a wife and three sons and we as a family need this truck to run so any help would be awsome guys!
I am picking up a 86 k5 blazer as my new dd but untill it is ready this is all i have. i dont have cash for a new truck so i bought an old one, plus i can fix anything on it. but this is still needed so please if you have any idea let me know!
    • Evan Williams Bottled in Bond   So pouring the last of a bottle of Evan Williams Black label last night I set off the the state store for a refill only to be denied the by an empty shelf. Rats.    What the did have was a bottle of Evan Williams Bottled in Bond. 100 proof. Hum, a few bucks more but a known distiller. Lets have a swing at it. ( I have before )    Cracked it open and pour a serving over ice. Hum.... more heat, yes. More alcohol naturally. But the barreling not the proof brings the taste and this one came up short.    Oh is was familiar but the heat ran the barrel over like a Peterbilt runs over a squirrel. Could use a heavier toasting of the oak me thinks or perhaps a longer barreling. Who knows. But what I can say is ice or a water back isn't the answer. What kills one kills them both. Sad. It is a pleasant drink....if you have little to compare it to.
    • I've had exactly one set of Bridgestone. Lasted five year and 125,000 miles and had I known better 15oK would have been a cake walk. I would have bought a like set had they not tripled in price since the first set. I removed them at said mileage with 5/32" remaining in dead even wear all four. They were fuel efficient, quite, comfortable and predictable.    Early on I got a very good alignment checked at least once a year, sometimes twice; kept the tires properly inflated, balanced and rotated. And I've found that many a tire issue can be avoided with great maintenance practices. Lot's of tire dealers will do rotation and balance (simple) for free for as long as you own the tire they sold you so no excuse not to.    Bead prep, alloy integrity and stem health have a huge impact on inflation stability. There are more mountings done poorly that perfectly. Finding a good tire guy is gold and as important as finding a tire you like.    That 3X price increase now two sets of "other tires' later is starting look like a bargain.      Bad maintenance kills more tires than bad tires.
    • Atlas, you kill me As aggravating as a project like this can be you have been unable to hide your fascination with learning and using that angst against this beast like a Ninjitsu Master. It amuses you, admit it now.      BTW, love your writing style. 😉
    • I gotta say, I'm enjoying your narration. The troubles you've been having are amusing as you describe them. It's good to see that you're finally getting some satisfaction out the old beast though.
    • Declaring victory would upset the demons that possess this Blazer, so I won't. But I did make progress today--after it put up a fight. Always a fight.   I had the day off so I spent the morning cleaning up the shop and I thought I'd get ahead of things by filling the cooling system in prep for the final part I needed to arrive: the driver's side knock sensor. Glug, glug, glug....and then the unmistakable sound of liquid hitting the shop floor. It induces the same chagrin when the sonar and targeting laser temporarily malfunction during a late night bladder evacuation over the toilet with the bathroom light off. D'OH!!! That made a mess...   Oh, hey, that knock sensor I removed? It threads into a wet port. Who knew?! Learn something new every day. Put a pin in that chore, I'll fill it the rest of the way later.   The knock sensor arrived at about 1pm. I threaded it in, connected the wire, filled up the coolant, checked for leaks, and... drumroll.... fingers crossed for a perfect start, excellent timing, model fuel trims, and ...no squeaks... Here goes.....   No, it didn't start. At all. I cranked it a few times and it wasn't sounding good. Furthermore, I heard leaking again. Jesus H Tapdancing Christ, stop leaking all over the dang floor. This time I had accidentally overfilled the coolant reservoir and the churn of the water pump via cranking caused a bit to burp out. Ok, just, breathe... Put the flamethrower down. Dang thing wouldn't burn anyway, leaks too much...   Did you know the rotation of a round crank sensor in a round hole, matters? I do now. Took me about half hour to retrace steps and realize what I had done. Then it started right up.   No squeaks. The squeak was the old balancer.   Once it entered closed loop, fuel trims are dead on, hovering right around zero at idle. No more -30%. I'll credit the injector rebuild on that one.   Timing? I think there's an OBD 1.5 translation error with my Actron scanner. It's anywhere from -20 to -30 at idle, sometimes as high as -40 cruising. Sorry, the engine just isn't running that smoothly at -40 degrees ignition advance. It's just not. It's smooth all through the rev range and has decent power. I'm going to have to trust the seat of my pants on this one.   The new exhaust is very quiet. The old catalytic converter? Not melted, but definitely not healthy. Rains glitter when you turn it on its end...all the precious metal is flaking out. Once the new exhaust system burned in/smoked off a bit, the engine's exhaust smell is normal again. Not that I'd recommend going around huffing car exhaust, but, you know what I mean?   One problem to correct. The new exhaust has the opposite problem of the old spliced up exhaust. It wants to hit the floor where the old one wanted to rest on the cross member. Happy medium, please? Still noodling on that one, need to look at how I can adjust some hangers.   I don't know what's next. On one hand I want to run away from this thing as far and as fast as I can -- there have been a lot of NOT fun moments. On the other, now that it kinda drives nice, maybe drive it around for a little bit?   Shhh... it's not currently dripping oil all over the floor. I can see just a little wet at the bottom of the timing cover where it meets the oil pan seal. It's not dripping multiple drops with every ignition cycle, in fact, after some driving this evening it has yet to even form a drop that could drip off yet. But the weekend is young... I fully expect this could turn into Exxon Valdez by Sunday. Because this Blazer hates me. LOL.
