Throttle body cleaning tips?
I have a 2007 GMC with the 4.8l. with 95,000 miles.
I've been getting a check engine light with the P0120 code referring to the TPS sensor. So, I figure it's time to clean the throttle body first.
Anyone have tips for cleaning it? Does it have to be re-set if it gets unplugged or should I just disconnect the battery?
