radio wiring different from all schematics
1998 Sierra 1500 SL manufactured in Oshawa, Canada. My dash wiring doesn't match manual schematics. Online diagrams say dark green wire is right front negatv, light green is right front post. My dash has dark green, dark green w white stripe, medium green, and lime green. Also purple wire with white stripe does not appear on any diagram. But I have NO solid purple wire (I thought they come in pairs). Wiring appears to come directly from behind dash with no aftermarket mods. There was a aftermarket CD/ stereo before thieves grabbed it. Is there an alternative wiring?
The radio wiring hanging out of the dashboard has a purple wire with white stripe. ShouIdn't there also be a solid purple wire? For speakers, wires often come colored in pairs. There is a dark green wire and a dark green with a white stripe. No other striped wires. Is it likely that the radio thieves completely ripped out a purple wire? Does anyone have any idea where to find more variations of audio wiring diagrams?
It's possible that the factory plug was replaced with an aftermarket plug when the non factory head unit was installed thus the reason that the wire colors don't match....
Factory wire colors:
LF+: Tan
LF-: Gray
RF+:Dk. Green
RF-:Lt. Green
LR+:Brown
LR-:Yellow
RR+:Dk. Blue
RR-:Lt. Blue
12v acc: Yellow
12v constant: Orange
Lights: Gray
Ground: Black
I agree with the factory color-wiring scheme above,so I need to find out my wiring and why it's different.
How do you tell which yellow wire is for which? Is there a test with a mutli-meter?
My wires hanging out of former radio slot (15 wires):
black
grey
yellow
yellow
dark green
dark green with white stripe
medium green (Lincoln green?)
lime green
purple with white stripe
orange
orange (a little lighter orange)
tan (possibly grey)
blue (royal blue)
light blue
dark brown
These wires come out of the back of the dash. Do you think they're spliced onto the factory ones? I can't see anything back there. I have air-con, which works, and cruise control, which conked out 6 mo ago.
    Sothpaw27
    Sothpaw27
  • Who's Online   2 Members, 0 Anonymous, 413 Guests (See full list)
    • Can it still be Assembled II?   Viscosity on the decline by various means. Heat on the rise making that worse. Engine RPM in the tank. Smaller motors with more boost trying to emulate an electric motor. Full torque, zero rpm. Then we will triple the OCI. Argh.    But wait....there is more. LSPI has pushed a shift from Ca to Mg and as that cost more PLUS the run to lower sulfur compounds the TBN is moving in the wrong direction for the increased OCI's demanded.    That not being enough to placate a demand for a parameter they can't measure the other sulfur bearing compounds are also under attack. That would be zinc and phosphorus sulfonate compounds. To some degree those are being replaced with boron esters and others, i.e. titanium ect. All of which have shorter service lives. And there there is the "Secrete Sauce" marketing for AW adds that 'Can't be detected by UOA's" but trust me because I (the blenders) never ever lie.    Spoiler alert; ALL additives are sacrificial! Smaller amounts of the old blended with less robust versions of the new do not equal longer service lives. So what are the blenders recommending? Wait for it.......   MOVING THE GOAL POSTS! OMG      Let's declare the long standing TAN/TBN crossover irrelevant and tell people that soot is a great 'graphite' based lubricant which can aid tribo films. Wait, what? Let's declare that the standards used for oxidation and nitration were to conservative and can be expanded. Let's tell them that because GDI fuel dilution, although being a VISCOSITY KILLER and an acid generator is actually okay because we have better base oils that limit viscosity failure limits. (Said knowing this is measured in fractions of a centipoise and in bases not commonly used in shelf oils)   Lying from the heart is not just the new normal but we have a public, a very young public, that is so ignorant of the facts and so sure of their "RESEARCH" into AI driven models base in regurgitated  instead of scientific research based unvarnished, peer reviewed FACTS that the incoming guard is loosing their grip on reality and the OEM's are tickled pink while the blends bend the knee.    You have an ever limited set of tools to work with. And sooner or later those will be taken from you as the API and the EPA strangle the last remaining fluids from the system. What you have left is your wits. If you care to use them.    At some point in the very near future it will not longer be possible to do "What is best for the machine", and be replaced with "The best you have access too". You WILL be rewarded with half the life and twice the cost. That isn't that hard to predict.
