GMPP (Borla) Sport muffler
$70 delivered in the lower 48. Will ship to Alaska, Hawaii, and Canada at actual shipping rate.
This GMPP stainless Sport muffler has less than 300 miles on it,
I purchased both the GMPP (made by Borla) Sport & Touring mufflers to install on my truck so I could see which one worked best for me.
I ended up keeping the Touring model because my wife thought the Sport was just a bit to loud. She gets a vote since we take my truck on my long road trips and when momma's not happy, nobody's happy! lol
Anyways, I have my Sport muffler up for sale. It was never welded on, only clamped with Accuseal stainless clamps which I highly recommend BTW!
Its in great condition, only has some minor scratches from shipping and handling. No dents or damage.
I was able to mount both mufflers on my 2012 sierra CC 1500 5.3 by just cutting the factory muffler off with a sawzall. If you do it yourself, make sure and cut the pipe as close to the stock muffler as possible to make sure you have plenty of room for mounting the new muffler. I had no problem with mine.
Cutting old and mounting new takes less than 30 minutes for anyone that knows there tools.
Here is the link to the muffler on Borla's site:
http://www.borla.com/products/product_detail.aspx?prod_sku=19131347
Here is some sound clips I made with my Iphone of both mufflers on my truck for reference:
And here is a link to the thread here on GMT that started this whole frenzy:
http://www.gm-trucks.com/forums/index.php?showtopic=145672&hl=
Can you tell me what the sizes are of it. I have a 2007 NNBS GMC Sierra and wasnt sure if it was the same sizes as your truck or not?
Thanks
Andy
I assume you mean, what size is the exhaust pipe / tubing? Mine is 2.5in from the third cat on back.
btt
The muffler has been sold Pending Funds to Gray 08. Thanks
Sold to Gray 08
    • "Teardown" is complete. Head surfaces are clean and ready, new intake is prepped and ready. Coolant drained and water pump is removed, radiator is removed, new hoses and pump are ready.   The replacement intake is also from a '95 (with I think 260k, the odometer said). Noticeably less pitting where it covers the rear coolant passages. I'm not sure if that's a tribute to more frequent use, more frequent coolant changes/upkeep, or if the intake was machined at some point. But it appears I found a good one.   My coolant hoses were original, and the lower hose still retained the factory spring inside. It's not really rusty, but it's got deposits all over it. Unsure if I should re-install it (will thoroughly clean it first). Someone said hose technology has gotten better since 1995 (has it?) and I don't need the spring. I think modern EPDM is what made those hoses last from 1995-2026, so it's a question of how much suction can the water pump really pull, and will it collapse the hose without a spring?   I'm stopped and waiting for parts, however.   When I first brought the truck home, the fan was intermittently hitting the radiator shroud. I could see someone had monkeyed with the shroud (put a bunch of cardboard as a spacer between the upper/lower shroud halves. Someone said the motor mounts have likely failed and the engine has sagged. I wasn't sure I believed that. The engine is really solid in its mounts: To remove the old intake I *just* nearly permanently welded to the heads with freshly cured RTV and gasket snot two weeks ago, I literally had to use the arms on my lift and a chain with a bolt attached to the intake to pull it loose. It almost picked the front of the truck off the ground before ....scuuuuuuuuuuup.... I could actually hear the gaskets tearing and it broke loose and the whole truck settled back down. Motor barely moved.   SO, those parts I'm waiting on... The lower radiator mounts/bushings had completely failed. The radiator needs to be insulated from the rad support, and the bushings help the rad stand at the correct height. The plastic "baffle" was also destroyed at some point. Someone had attached the shroud to it incorrectly, overlapping a joint that should have been underlapped, creating another suspect issue potentially causing things to hit the fan. Broken tabs, side is busted off, and it's perma-formed/bent where it was jimmied incorrectly.   The baffle? Unobtainum. Long since discontinued from GM, of course. Aftermarket/capa/chinese? Also unobtanium. In GM's infinite wisdom, it appears there are at least two different variations whether the Blazer is 2 or 4 door, and I can't yet tell if they shared the same part with the S-pickups. Plan B, if I can't find a viable used one, will be to create a bracket to re-assemble the critical joint I need to seal a gap with the shroud. But that will bug me, it won't be...perfect.   The water pump bolts appear to have been installed with...plumber's putty. I guess, sure, if it works...? I've found a few "backyard fixes" like that. Someone's been here before....   If I can't find someone to jam bamboo under my fingernails to fill my free time this week I think I'll install the driver's power window motor and replace the rear door speaker that's inop. I've got a genuine GM "9.5" ohm working replacement. Why GM used a non-standard resistance....nevermind. Of course they did, you can get more sound from a cheap factory amp that way.   And the saga goes on...
