Short in Backup Light Circuit
I'm trying to find the cause of a short in the TCB2 fuse. I got the helms manuals and have the circuits involved memorized at this point. Several years ago, i cut the wires under the dash feeding the backups lamps and interior lights so i could isolate. The interior lights by themselves work fine, but reconnect the light green wire for backup and it'll blow the fuse within a day.
My next steps are to isolate/disconnect the feed from C3 connector in the Relay I/P Block that leads to the rear view mirror and make sure i didn't short the wires in the A pillar when working in there before...
If that fails to be the cause, i figure i got two options:
1) short between C3 connector an the lamps
2) short at S211 to RPA or in the line to the RPA control module.
So my questions:
1) i've seen alot of posts about this same with no concrete resolution. I suspect there's a problem from the factory in the harness. Anyone have a definitive/common cause?
2) anyone know where the S211 splice is located?
thx in advance
-brad
if it's not in the A pillar like you said, i'd check the factory distribution block at the rear where the harness feeds into the taillights/trailer wiring. they can get corroded and short out over time. i've seen that often
well i looked for a half hr ,s211 is down from BCM ,near center concole ,i couldnt find a pic ,also its C! at relay block not c3...
disconnect RPA instead of finding s211
also ,there is a fuse for the back up lamps so im confused why you say its the TBC2 fuse (which doesnt exist ) either TBC2a,b,c, for bcm
stop cutting wires god dam it !!!! lol
this may be over your head without proper schmatics and experience ,plse take no offence ,,,,shorts are a PITA
isolate 1 piece of the schmatic at a time and check ,
like i said ,it makes no sence to me ,,,im out
good luck
WELCOME TO THE SITE !!!!!
thank you both for the tips (and sorry for botching he fuse - was going off memory there but i've replaced it enough, i should know). . but i'm sticking by c3 (pin A) via my 2003 manual 8-220 / 8-1118 (unless the 05's changed)
no offense taken at being over my head - my dealer passed on it - and i might just give up too. If i don't find it, i'm prepared to add a relay to the wire coming from BCM and wire from a new source (or tap the trailer backup lamp feed for the relay coil - i tow and plan on adding docking lights to the trailer via that circuit). I would prefer not to go down that route either as i just dropped money on leds wondering if the lower wattage would fix magically fix it. It did not - go figure :)
anyways, on the hunt... thx again
-brad
This may be a stupid question/suggestion, but, you did check the backup light socket/bulb didn't you?
    Greg3160
    Greg3160
  • Who's Online   0 Members, 0 Anonymous, 446 Guests (See full list)
    • Late reply, but yes—it works on the SLT trim. Compatibility comes down to the plastic shroud shape behind your mirror, not the trim badge itself. On the SLT with auto-dimming, it uses a plug-and-play Y-harness off the mirror/rain sensor power, so no need to run wires down to the OBD port. If anyone's ever unsure about fitment, just drop a photo of your mirror housing and we can double-check it.   Appreciate the detailed feedback on the install! On the windshield glare—we actually took feedback like yours and developed a dedicated CPL (polarizer) filter to cut down dash reflections on sunny days. If you're still running the cam, shoot me a DM. I'd be happy to send a CPL filter over for you to test out—no charge.
    • There are no stickers in your glovebox?
    • Look at the numbers on the stickers in the door jam...
    • Yes, every time the developer updates his code, you must recompile. I will private message you with the latest because it changes pretty much with every version.
    • After I wrote that reply I went for a ride. 85 F out. So trans started at 85 F and it shifted the same as it did an hour latter at 168 F. I've never actually recorded the to cold to shift point but it is under 32 F before they start hanging on to a lower gear or leaving the converter unlocked. Both intended to heat fluid.    Yes, brake or bake. Absolutely.      Your welcome. True research ended decades ago. Field trials are still in play.    There is a thing called oxidation onset temperature. This is the heat related oxidation not the O2 exposure kind. For mineral oil that starts at 140 F. So what happens after 140 F? Each 20 F cuts fluid life in half! Does using a Full Synthetic improve that? Yes! By how much? Depends on the base oil type and a few other factors. But enough to notice. Some esters are even higher. There are even synergies between types the will raise it higher than any one component is alone.    Then there is "Hindered" oils. Antioxidant additives. Hindered Polyol Esters can sit at 500 F for years in a turbine.   When a blender brags his oil will 'take 500 F" in service he doesn't specify for how long. Water will dance on a 500 F hot plate for several seconds. @newdude put up a chart showing the relationship between fluid temperature and it's life in an automatic transmission. Here's a version of that chart for Group III based oils. These temperatures are those in the pan as observed as 'normal'. that is you drive as you do for as long as you do under what load you ask of it and whatever that temperature is this graph applies to. Flash temperatures of a few minutes isn't what his means.    Note that fluids held at a constant 240 F have a service life of only 20K miles. 220 F explains the factory exchange limit, eh? My equipment I keep under 180 F and I'm good if the cooler will hold it as low as 140 F. But that's me.
