2003 SILVERADO LT A/C PROBLEM
ROBERT 03
CLUTCH WON'T ENGAGE ON COMPRESOR, EVERYTHING GOOD FUSE,PRESURE IN SYSTEM,I PUT JUMPER WIRES ON EACH SWITCH HIGH AND LOW STILL NOTHING, IF I REMOVE THE RELAY AND PUT A JUMPER WIRE CLUTCH WILL ENGAGE AND PUT OUT COLD AIR
Bad relay, or no power to primary side of relay.
AND I SWITCH THE RELAYS AROUND AND THERE IS TWO HOT TO THE RELAY ONE ALWAYS HOT AND ONE KEY ON
    Brendan C
    Brendan C
  • Who's Online   3 Members, 0 Anonymous, 1,149 Guests (See full list)
