Edge CTS gas tuner, reviews?
After trying a search on the site I havent found any similiar posts. I currently have a diablosport tune on my truck and I dont really like the settings they programmed with it. Ive been looking into buying an Edge CTS 4.3" touch screen in dash tuner for my truck and was wondering if anyone has ran this tune and what theyre opinion is? I want to be able to switch from economy, towing and performance tune. That is an important factor to me.
    • you might read through the info on gmupfitter.com for your truck, to find a good power source.
