what is gms pricing
bowtiefan
HEy guys just wondering what gms pricing is i have seen it ona few psot were some guys got a new truc kand got them with the gms pricing and it saved them alot. Is it something that anybody can get or is it just for people who know people who work at chevy dealers or gm plants. Man you can save a bundle with that pricing.:):):):):):):)
GMO/GMS pricing are discount programs offered to GM employees, spouses, retirees, etc.  They are also offered to various others through corporate agreements/partnerships.
I work for General Electric, and I get the GMS plus 4% deal.  I have found that this is a no haggle price  that is about invoice plus or minus a few hundred...  You can also apply any discounts or rebates, so it is a good deal...  they do hurt you on your trade but if you bought it the same way then it is a wash...
Well i guess a gms discount does not apply to me since i dont know anybody that works for gm that sucks lol.I do have abuddy that works at chyrsler plant here in syracuse that said he could get me a discount on a dodge truck but i said no thanks not a dodge:(fan.
GMS is a SWEET deal.  My company does business w/ GM and they extended the offer to us.  I picked up my truck through the program.  Best car buying experience ever.  No haggling, BSing, lying, cheating, etc.  Here's the price in black & white, and still took advantage of the incentives!  Trade in was even pretty fair (worn out '94 S-10 Blazer).  Great program if you can get in on it!
