DOD lifter replacement on 07 6.0L L76
I was just wondering if anyone would have an order sheet with the parts a guy would need to replace the DOD lifter myself. took it to the dealer and they wanted way too much to fix the issue. It is just the cyl #1 intake lifter that is stuck shut (I pulled the valve cover to be sure).
so far what i have is:
intake/exhaust lifters
intake gasket set
Head gasket
Head bolts
Exhaust bolts
*I plan to re-use the coolant, and change the oil as well.
Thanks
Contact member: MS3Dale, he can find all the part numbers you need.
As a side note, depending on the age of your coolant I'd go ahead and change it out since your already going to have it apart. Just my opinion.
    CaptainDad
    CaptainDad
  • Who's Online   2 Members, 0 Anonymous, 593 Guests (See full list)
