"Service Battery System" - Help with Battery Problems
airomero83
All right guys I need your help on this dead battery problem I been constantly having. 2007 Chevy Avalanche. One morning battery was completely dead...couldn't even jump it. Took it to AutoZone thinking it was a completely dead battery but turns out battery is all good and they charged it completely. 2-3 days later of driving, battery was dead and can't turn truck on again (all interior lights and everything working). This time I can jump start it and let it run for a while. I proceed to remove negative cable with truck on and let it run for 5 minutes and stays on. Alternator good right?
Take it back and they tell me battery is good again and do a load test and tell me alternator is fine...but that apparently battery is not being charged. So it's gotta be a connection problem? Any blown fuses/relays I should check as well?? I've had issues with AutoZone when they have told me batteries were good when they were really bad. Should I second guess them? Anything else I should look for? I have a feeling it's the alternator. When truck is running, the battery gauge on instrument panel is a little over 14V so battery appears to be good.
Thanks for all the help!
its charging at that voltage ,,,,
you should have a load tester squeak some amps out of alternator to be sure and a parasitic draw test done also,and while they are at it ,charge the battery completely and load test the battery ,,
I've had this issue with mine since day 1. Killed the battery almost completely listening to the radio while working out in the barn when the truck was 4 days into my ownership. Was able to bring it back with the charger I have, & I had the dealer tweak the computer for a little more output -- the alts these days are computer controlled. When they sense a full charge, the field is cut & the alt becomes just another idler pulley. Apparently, when it charges can be adjusted. Now that my truck spends more time sitting than anything, the battery will get weak after a couple weeks of no use. Most computer controlled vehicles have a constant , small, milliamp draw on the battery, so when they sit, an occasional charge is mandatory. Price we pay for "progress" I suppose ...
For the cost of a good battery, you can get yourself a charger that will pay for itself many times over. I brought my battery back with this, and HUNDREDS of others that were ready to be scrapped. Well worth the money. The key is the temperature sensor. It also has technology that supposedly breaks up sulfation. I can tell you this: IT WORKS!
You can shop the net for a better price, but you can use this to get all the info on it: http://www.northerntool.com/shop/tools/product_200326706_200326706
EDIT: Looks like they cheaped out and don't include the temp. sensor anymore - make sure you get that sensor!
Thanks for the suggestion and sounds like a good investment. Definitely picking one up. And not surprisingly, it was a dead cell in the battery. ALWAYS second doubt those autozone guys. This has happened one too many times for me
I know this may sound odd but it happens to my dads Chevy Work van all the time, do you have anything plugged into a cigarette lighter that is hot all the time? If so unplug it! Even if its a cell phone charger with no phone attached..My dad went through hell and high water, couldnt figure out why his battery kept going dead overnight yet the battery load tested fine...he has a dewalt charger for his 18 volt drill battery plugged into cigarette lighter and even with no battery in the charger at all..it will kill the battery over night, he unplugged it and for weeks the battery didnt die, then one day he left it plugged in (again with no battery in the charger) came out next morning and battery was dead.
Airomero, I'd be willing to bet that charger would more than likely bring that dead cell back. It's amazing what that charger can do. Not all the time, but 90% of the time i can bring a battery back.
The batteries in my John Deere lawn tractor & Polaris ATV were both dead within a week of ownership, back in '05 when they were new. I managed to float them along with a conventional charger until '08, when there seemed to be no life left in them. Used that new charger in '08, and both batteries came right back and held a charge.
I just replaced the Polaris battery last week, and the John Deere battery, which most people would've scrapped already, will go on in service for season #8. Only reason I changed the Polaris battery is due to the constant FI draw. I use it mostly for plowing. Between idling, and running the winch, heated grips, heated seat, and heated thumb throttle, it puts one hell of a load on the battery. Without lots of high RPM run time coupled with the parasitic draw, the battery would be weak whenever I started it up on cold winter mornings. The battery is actually still good - I just went to a AGM deep cycle instead.
That charger is well worth the cash. :cheers:
    Whit.the.COB
    Whit.the.COB
  • Who's Online   3 Members, 0 Anonymous, 1,217 Guests (See full list)
    • I've had exactly one set of Bridgestone. Lasted five year and 125,000 miles and had I known better 15oK would have been a cake walk. I would have bought a like set had they not tripled in price since the first set. I removed them at said mileage with 5/32" remaining in dead even wear all four. They were fuel efficient, quite, comfortable and predictable.    Early on I got a very good alignment checked at least once a year, sometimes twice; kept the tires properly inflated, balanced and rotated. And I've found that many a tire issue can be avoided with great maintenance practices. Lot's of tire dealers will do rotation and balance (simple) for free for as long as you own the tire they sold you so no excuse not to.    Bead prep, alloy integrity and stem health have a huge impact on inflation stability. There are more mountings done poorly that perfectly. Finding a good tire guy is gold and as important as finding a tire you like.    That 3X price increase now two sets of "other tires' later is starting look like a bargain.      Bad maintenance kills more tires than bad tires.
    • Atlas, you kill me As aggravating as a project like this can be you have been unable to hide your fascination with learning and using that angst against this beast like a Ninjitsu Master. It amuses you, admit it now.      BTW, love your writing style. 😉
    • I gotta say, I'm enjoying your narration. The troubles you've been having are amusing as you describe them. It's good to see that you're finally getting some satisfaction out the old beast though.
    • Declaring victory would upset the demons that possess this Blazer, so I won't. But I did make progress today--after it put up a fight. Always a fight.   I had the day off so I spent the morning cleaning up the shop and I thought I'd get ahead of things by filling the cooling system in prep for the final part I needed to arrive: the driver's side knock sensor. Glug, glug, glug....and then the unmistakable sound of liquid hitting the shop floor. It induces the same chagrin when the sonar and targeting laser temporarily malfunction during a late night bladder evacuation over the toilet with the bathroom light off. D'OH!!! That made a mess...   Oh, hey, that knock sensor I removed? It threads into a wet port. Who knew?! Learn something new every day. Put a pin in that chore, I'll fill it the rest of the way later.   The knock sensor arrived at about 1pm. I threaded it in, connected the wire, filled up the coolant, checked for leaks, and... drumroll.... fingers crossed for a perfect start, excellent timing, model fuel trims, and ...no squeaks... Here goes.....   No, it didn't start. At all. I cranked it a few times and it wasn't sounding good. Furthermore, I heard leaking again. Jesus H Tapdancing Christ, stop leaking all over the dang floor. This time I had accidentally overfilled the coolant reservoir and the churn of the water pump via cranking caused a bit to burp out. Ok, just, breathe... Put the flamethrower down. Dang thing wouldn't burn anyway, leaks too much...   Did you know the rotation of a round crank sensor in a round hole, matters? I do now. Took me about half hour to retrace steps and realize what I had done. Then it started right up.   No squeaks. The squeak was the old balancer.   Once it entered closed loop, fuel trims are dead on, hovering right around zero at idle. No more -30%. I'll credit the injector rebuild on that one.   Timing? I think there's an OBD 1.5 translation error with my Actron scanner. It's anywhere from -20 to -30 at idle, sometimes as high as -40 cruising. Sorry, the engine just isn't running that smoothly at -40 degrees ignition advance. It's just not. It's smooth all through the rev range and has decent power. I'm going to have to trust the seat of my pants on this one.   The new exhaust is very quiet. The old catalytic converter? Not melted, but definitely not healthy. Rains glitter when you turn it on its end...all the precious metal is flaking out. Once the new exhaust system burned in/smoked off a bit, the engine's exhaust smell is normal again. Not that I'd recommend going around huffing car exhaust, but, you know what I mean?   One problem to correct. The new exhaust has the opposite problem of the old spliced up exhaust. It wants to hit the floor where the old one wanted to rest on the cross member. Happy medium, please? Still noodling on that one, need to look at how I can adjust some hangers.   I don't know what's next. On one hand I want to run away from this thing as far and as fast as I can -- there have been a lot of NOT fun moments. On the other, now that it kinda drives nice, maybe drive it around for a little bit?   Shhh... it's not currently dripping oil all over the floor. I can see just a little wet at the bottom of the timing cover where it meets the oil pan seal. It's not dripping multiple drops with every ignition cycle, in fact, after some driving this evening it has yet to even form a drop that could drip off yet. But the weekend is young... I fully expect this could turn into Exxon Valdez by Sunday. Because this Blazer hates me. LOL.
    • About that:   Once upon a time in a land far far away lived a car company that was shy about taking your money and wanted to be sure that they gave you more that you asked for so that you'd come back. No really, not a fairytale. 😱   But after the field got thinned out enough to limit the competition it seemed good enough to give you only what you asked for. Fair enough I say but in such a market you have to give something the others are not or they go to the one who does. Gimmicks or glitz. Oh, fins and chrome. Yea, shinny crow like cars. Yum.    Field narrows a bit more and 'brand loyalty' becomes a thing and the minute it does they start thinking to themselves, "Could we make more money if we gave them less than they expect and they will hang in there for brand and comfort with the known?" They gave it a try and da*n, it worked!!    Well, what if we teach them, groom them into believing that less is "Normal" and cut some more corners. Will that work? Oh heck yea!    🤔 I wonder, can we give then WAY less than they expect and make them mad enough to spit nails and STILL get them to pay up? Sure, if we get everyone else to do the same so that the choice is less or nothing at all. How would be do that? Platform sharing.  What a concept, right?  Steal like there is no tomorrow and it's legal too!    Truth is no one is going to give up driving, not for very long. The Gen Z crowd is fine with it and will be as long as someone not Gen Z will haul them around. At some point we all die.    Economic voting only works if you cast a NO vote now and again and enough of them to get dumb and dumber to wise up. Well, that's how I was taught anyway. And it should have worked. Would have worked. But the Bail out!!   Look, you have another choice if  you take that bag off your head. If the dumb it down to some predetermined expectation of how John Q Public will use it the, that is under design it to failure they you use it to a lower stress mode. D'ho!    A 1950 Royal Enfield Bullet 500 will go anywhere a Suzuki Hayabusa will and for just as long. But you will have to treat it for what it is and not for what you wish it was.
