Workaround for sirius/xm not booting up on OGM-1
Have not posted in a while so I am not sure if this has been called out or not, but I still have issues every once in a while with my XM not booting when i turn my truck on. The OGM-1 brings up the XM screen, but does not play or provide data for anything. The only way to get it to work is to reboot the OGM-1, just turning it on and back off will not work. The only way is to turn off the truck and open the door to get the OGM-1 to reboot. As we all now, this can be a PITA if you are already driving. I found a little trick yesterday that reboots the OGM-1 without having to shut the truck off. If you go to the menu screen and in the bottom left there is a button to change the color of the touchscreen buttons (Blue or Orange). If you press this, it requires a reboot to change the color of the buttons. This allows you to reboot and get XM without turning the truck off.
Just thought i would share...
I sometimes have the same problem. Next time that happens, I'll try your recommendation. Thanks for the advice.
You can also hit "System Reset" on the second page of the Settings menu...
