What should oil pressure gauge read on a 2011 5.3?
SLong
I have a 2011 Silverado Z71, 5.3 with 70K miles. I have a question as to what oil pressure gauge reading I should be seeing on my truck. When I first started my truck this morning, it read around 50 lbs of oil pressure. Once I drove 4 miles or so and got on the interstate, I looked at it a few miles later. Over the course of a 40 mile ride on the interstate to work, it read between 32-38 lbs on the oil pressure gauge. I could get it to go up to 40 but it required getting on the throttle pretty good to simulate a passing situation. I think I seem to remember it staying at 40 lbs during interstate travel over the life of the truck so far. Is the current pressure readings something to be concerned about? I am curious if this is a sign of a lifter going out or something else to have checked out. Thanks in advance for any feedback.
Seems normal, suppose to fluctuate at speeds so as long as it isn't reading 0, you should be good.
this minimum pressure on a hot engine
24 psig at 1,000 engine RPM
35 psig at 2,000 engine RPM
38 psig at 3,000 engine RPM
My 09 in right on the minimum specs, burns a liter per 1000kms. Damn, I picked a winner of a used truck!
My dealer says my issues with my truck is normal and won't take the time to look into it further. I guess I'll run it until its knocking and then they can fix it.
normal my butt,,,check this.......
Oil Consumption Diagnosis
Checks
Causes
Excessive oil consumption, not due to leaks, is the use of 1 L (1 qt) or more
of engine oil within 3 200 kilometers (2,000 miles).
Preliminary
The causes of excessive oil consumption may include the following conditions:
  • External oil leaks
    Refer to Oil Leak
    Diagnosis
  • Incorrect oil level or improper reading of the oil level indicator
    With the vehicle on a level surface, run the engine for a few minutes, allow
    adequate drain down time, 2–3 minutes, and measure for the correct engine oil
    level.
  • Improper oil viscosity
    Refer to the vehicle owners manual and use the recommended SAE grade and
    viscosity for the prevailing temperatures.
  • Continuous high speed driving and/or severe usage
  • Crankcase ventilation system restrictions or malfunctioning components
    Refer to Crankcase
    Ventilation System Inspection/Diagnosis
  • Worn valve guides and/or valve stems
  • Worn or improperly installed valve stem oil seals
    Refer to Spark Plug
    Inspection
  • Piston rings broken, worn, or not seated properly
    Allow adequate time for the rings to seat.
    Replace worn piston rings, as necessary.
    Refer to Cylinder
    Leakage Test
  • Piston and rings improperly installed or not fitted to the cylinder bore
    Refer to Lower Engine
    Noise, Regardless of Engine Speed
I changed my oil 2600 miles ago on my 2011. Checked my dipstick the other day and it was a hair down from when I changed it. It took 7 ounces of oil to get me back to my mark on the dipstick. Truck has 70K miles on it. Would you guys view this is acceptable?
    ballencd
    ballencd
  • Who's Online   3 Members, 0 Anonymous, 455 Guests (See full list)
