JOTD: Guns & Station Wagons.
Bad Bowtie2
This is a story... about the old days... :D
One of my grandparents and a friend worked in construction. Grandpa had owned his own company for a long time and they were driving out of the mountains from a site one day in a station wagon (I believe I had heard it was a mid- '50s Ford). Driving along, getting later into dusk, they see a full-grown deer just off the road out in a field. Being good old boys they saw this as an opportunity and pulled off. There were two weapons available to them in the back of the station wagon, a .22 rifle and a hatchet. Grandpa took the .22 and put a shot on the neck. Nothing fatal, but, enough to slow the deer down. Gil, his friend, noticing the deer not dead, grabs the hatchet and turns to Grandpa and says, "I'm gonna' get that motherf*cker." Now, remember, this is late in the evening and getting fairly dark. Cars are silhouettes and headlights, blah blah. Anyway, Gil just sprints full speed at the deer who is too wounded to do anything at this point. Bad part was, Gil couldn't see the barb-wire fence right in front of him. WHAM! Down goes Gil. And a moment later he gets right back up and continues after the deer and "subdues" it with a hatchet. They drug it back to the car and brought it home. I'm told the station wagon never did smell the same after that, but, hey, they probably had dinners for a week each and a tidy sum to take to the butcher for profit.
Try doing that these days and see what happens.
Oh, and to this day, Gil still has scars around his midsection from running into the barb-wire fence!!!
:cool:
    DaleB
    DaleB
  • Who's Online   2 Members, 0 Anonymous, 1,303 Guests (See full list)
    • Common Sense Assembly   Your driveline is forgiving of the occasional mistake. It will even often forgive the random serious blunder. But it will not forgive a continuous bad habit.      What? Not everything needs to be a five thousand word essay.
    • We drove about 15 minute east today to visit a friend and saw a steep increase in price in the same county. About 50 cents a gallon steepper.
    • Sure about that? A degree wheel and a dial indicator would lower your degree of assurance in that statement. 😉    It why we have offset keys and dialable timing sprockets. Just say'n.... I've built a few and have never seen one "On the money".
    • I will admit I haven't experimented much with pressure drops beyond the numbers I put in and part of that is that the numbers I used are fairly low and then found out it would trigger regardless at that 35 psi. Having said that I had tried before had changed the placard pressures and being that I have a 1 ton set to 80 on the placard for the rear I believe it triggered close to 60, the front I don't recall now for sure but thought maybe it could get close to 45 from that factory 60 placard pressure. So I never did figure out if it was a number of psi from placard pressure to the alarm or a percentage of the total placard number as some figured it was like a 25% drop from placard pressure would trigger it. So as to try and answer your question, I believe I set the placard pressure on the front to 47 or so and while I run the front tires at 40, they have dipped below that some if its colder and I haven't put "winter air" in yet and never once have had the front alarm go off. I would say that the answer your looking for is no, that if you set your placard pressure to 45, you have a certain amount of room to drop below that pressure before the alarm will go off.    The pressures you decide to run in your truck, that ends up being what makes sense to you based on what your carrying in your truck or if towing, then have to bump them back up to something that will carry the load in the rear and the fronts typically left at the same pressure. It all comes down to that chart I put the link to and using an accurate roadside scale to be your guide, both unloaded and then loaded to know your minimum safe pressures.    I just wish GM would allow a person to change the readings for the tire pressures to the English system of pounds as I have to look at that goofy metric reading that will never ever jive in my head and will go over and change it just to figure out what they are if need be and then change it back.
    • That part I understand, that the dealer can do it. But I'm not understanding why updates that were available to the truck since it left the factory, or the dealership originally, would not still be available to it without dealer intervention.   I'm thinking along the lines of recalls. They stay available until they are completed, regardless of whether they are in warranty or not, or in the hands of the original owner or not. Why not updates as well, especially since some of those can be safety related also?
