3500 Clearance Cab Light
The Centre Cab Light will start to leak !!!
If you have the light it will tend to rise up in the middle due to warping and the crappy gasket that stops the water from
wrecking your headliner and soaking your floor is useless. If it has not happened yet it will.
Remedy: Remove the three Screws and silicone around the 3 Large holes where clips and wires go through the cab. Reinstall Light.
Scooby.
    • Yes, and also pulling heavy trailers or a large camper up steep grades as well as descending grades such as the more rustic off road camping locations and using engine braking with that low gearing as well as soft ground can just suck the power . I realize pickups these days tend to have an over all lower first gear ratio compared to automatic transmission pickups from years back so that has helped a lot in its ability in high range but there comes a point if in four wheel drive the torque runs out at the wheels, certainly with a gas engine. They don't put two speed transfer cases on pickups for a cool factor, they have a function if one needs that massive torque to the wheels that high range can't deliver.
