FS: 2011 Chevrolet Silverado LT 4x4 Z71 11,500
Selling my 2011 Silverado LT Z71 4x4 truck. Only 11,500 miles on it, and it is in excellent condition. No accidents or water damage. Bought it in Feb. of 2012. I'm offering this at a great price, because I need it gone by 6/04/13. It will be going to Carmax if I can't sell privately. The truck runs absolutely perfect, and I haven't had any problems with it. I am still financing the truck, so it has a lien on it which is something that will need to be worked out.
Asking $26,000 for it.
Here's some features:
5.3L V-8 with 6-speed
Z71 Package
Towing Package
Rear Park Assist
Running boards
Dual Zone AC
Rear Defroster
Power driver seat
4WD
Spray-in bed liner
Mud Flaps
Slimline Toolbox
18" Alloy wheels
FLEX Fuel
Traction Control
3Kc3L53Ff5Nf5K65J5d5u0711276fbd6f1814
3Eb3J63H15Ef5F85Med5uf968e9427ab91435
3Gd3K33Mb5Ib5E45F3d5u21818506a3ce16d8
3L13Md3Ib5Ee5F15H1d5uc4fd23368db91e12
3G43Ke3Nd5G55Ee5Jfd5u043040cfa69c135f (1)
3K13Jd3Hd5F55M45Jed5u9d95f5e6e24b1845
    AidenVorpagel
    AidenVorpagel
  • Who's Online   3 Members, 0 Anonymous, 1,260 Guests (See full list)
    • Can it still be Assembled I?    Stribeck says that we need a certain amount of viscosity under conditions of load and velocity to prevent two surfaces of a know roughness from tearing each other asunder. And we have marketing trying to tell the masses that those two surfaced require less of that commodity due to more exact limits being placed on the same old clearances. We also know that there are limits to how hard something can before it becomes to brittle to be viable and to smooth to 'wet' the surface and that both of those conditions have been known and met since about the Second World War.    That viscosity value shook out at 10 centistokes at 212 F just under a hundred years ago.  Give this a look: [Anton Parr]     What is advertised is the Kinematic viscosity (mm2/s) or that which has been density adjusted but the value we are after is the dynamic viscosity (mPa.s) or true viscosity. You can see that this number is dependent on density thus base stock and temperature. You can also see that an SAE 30 doesn't reach that value in this example. However an SAE 30 that is at the upper end of the SAE 30 range; 12.5 cSt (mm2/s), might. 12.5 * .83 = 10.375 (mm2/s). If you could find an SAE 30 at the upper end these days.   Then there is the complication of viscosity modifiers or VII or VM, whatever you wish to call them. Polymers added to very thin base oils, perhaps 3 to 6 cP oils, that will meet the SAE *W30 spec at 'tested' shear rates and 100 C/212F  target temperature. So a polymer fortified base that is a fraction of the 10 cP requirement Stribeck insist upon.   This could be all well and good if those polymers didn't have two very problematic 'features'. They shear or loose viscosity both 1.) permanently and 2.) temporality. And they do both omitted in the advertised data with the distinct  purpose of deceiving the consumer of the actual operating state of the fluid. I've shown the example of Warren Oils COSTCO 10.91 cSt 5W30 formuation several times where the 100 C HTHS value is 6.9 cP!! That's the temporary shear down and with and SSI or shear stability index of 9.4 cSt. Note the intentional deception in using mixed units?    After a short while that 9.4 cSt oil has a viscosity corrected dynamic value of 7.8 cP. But as the SSI is still within the range of an SAE *W30 whose lower value is 9.3 cSt.    This allows them to continue to call this SAE 16 weight oil a 30 weight, the cake, and still meet the API requirements for fuel efficiency IMPROVEMENT mandated by the EPA. The eating of the cake. By the time you've worn out your motor doing the responsible thing by adhering to the warranty requirements, (the stick), you get deprived of the carrot, wear control. So sad, to bad.   So what can be done? Do I need actually say? [Anton Parr]       Even this must be monitored if the oil is on the low side and the VII an organic or you opt for a 0W40 with an even lighter base oil and more / higher MW VII. (Note the lower density of the 40 weight versus the SAE 30 mono-weight?)    There is another workaround. Temperature. An SAE *W30 run at a bulk temperature of between 180 and 195 F.    Being the belt and suspenders sort I am I do both. Run it cook and run it heavy.    In Part II I'll work the AW package.
