Driver Power Window Issue
I have looked around on multiple forums to find the answer to this question. It seems to be pretty specific though so I will shoot it on here in an attempt to narrow my issue down. Yesterday my drivers side window switch stopped working. When it stopped working none of the other windows would roll down because the window lock button was stuck on. I pulled some of the fuses and it reset the window lock allowing the other windows to roll down from their respective buttons, still no luck with the buttons on the drivers side. The mirror adjustments will not work either. Also the radio is staying on when the drivers door is opened, however if the passenger side door is opened the radio will cut off. I figured it may be the BCM until the passenger side door turned the radio off and the other window buttons work. Also, my sunroof works properly. Im thinking it could possibly be the door jamb switch and the drivers door window switch (module). Rain water got in the drivers side the other day when the window was left open.
I am hoping I can get some answers. If I had more time on my hands I would pull the window switch out and attempt to let it dry and clean it with some electrical cleaner. I am stumped though. The vehicle is a 2004 Yukon Denali if that helps.
Thanks in advance!
Ryan
  • 3 weeks later...
    blueskytruc
    blueskytruc
  • Who's Online   2 Members, 0 Anonymous, 569 Guests (See full list)
