My 2001 Silverado has developed a rough idle. It feels like it is missing on one cylinder. I just changed the spark plugs, no change. I also just replaced the original battery.
I was thinking maybe a coil, or a fuel injector. I am not sure of the best way to troubleshoot.
It's a 2001 Silverado 5.3L auto trans. It's got about 110k miles on it.
Thanks
I kinda had the same issue but it only "studdered" every now and again. Good thing was it didn't affect any performance but I went ahead and changed all plugs and wires, both were due, and it turns out one of my spark plug wires was just sitting on a plug not fully compressed onto the spark plug. After all that, runs like new once more without any issues.
Check for codes.
Clean MAF and throttle body
Fuel filter
Fuel pump pressure
Check for codes.
Fuel filter
Fuel pump pressure
Great ideas, I will be doing this today. I will post back with what I find.
No codes.
MAF
Key on engine off fuel pump running. About 55psi
Key on engine off fuel pump off. About 52 psi
Engine running. About 48psi
Sorry about the focus, stupid camera.
Not sure how to clean the MAF, it looks kinda sensitive, I did clean the throttle intake.
Now I am thinking the pressure is a little low. I was thinking about a new regulator.
Thanks
Use MAF approved cleaner.
Fuel pressure is low. Check pressure reg. for presence of fuel at vacuum line. Replace if fuel is found
Thanks Guys, I will do this and get back to you.
Great qoute in your sig, how true it is.
  • 3 weeks later...
Just wanted to do a follow up on this.
The air filter was due so I put a new one in. Then cleaned the MAF, and installed a new fuel pressure regulator.
Well the truck idles much better now, it's not perfectly smooth but does not shake the whole truck like before.
I think what helped the most was cleaning the MAF. I replaced the fuel pres. regulator and checked the pressure and it was not much different then before. I also bought a new fuel filter but have not put it in.
Thanks to everyone for your help. :cheers:
    Brendan C
    Brendan C
  • Who's Online   1 Member, 0 Anonymous, 1,143 Guests (See full list)
