Factory head unit volume non-responsive
MikeF1185
I don't have RSE in my console so I don't have that answer. The amp, remove the front seats, back the console away from the dash a couple inches, then there should be 4 screws, 2 on either side of the console. Also remove the lid and storage bucket to access the plugs.
IIRC, is there a mute line from the amp? Or am I thinking of another GM vehicle....
It was used to prevent turn-on thumps. <insert comment here about Delco EE's> :dunno:
Also, I think the RSE stuff plugs into the back of the radio, anyone know if the radio will function w/o it plugged in? If so, maybe simply unplugging the RSE would be a way to test it as the cause or not.
    rayredbone
    rayredbone
  • Who's Online   1 Member, 0 Anonymous, 534 Guests (See full list)
    • Thank You.   So far my new ride is making me look like a genius for going with the 3.0L, as my first fuel refill occurred over three weeks from when I took delivery.  This engine combination is very amazing.  So far no issues and had not done a regen yet.
    • I am curious as to how much fluid you put back in the transmission ( assuming you had replaced the filter to compare to my findings ) and then went through the process of warming up the trans before pulling the check plug to drain out the excess and if you measured how much came back out.    I just found it surprising that some claimed a certain amount less fluid being put in and then draining some back out. The attitude of the truck as per if the surface is level and how the trucks stance is would make quite a difference since the check plug is right at the front of the transmission.
