Z71 Decals
Does anyone have the part numbers for the Z71 off road   decals that are on the rear sides of the new chevy trucks?
I know the 02's had the different ones but not sure if 01 had it or not.   Thanks!
Matt G.
I guess you could always go check out the following site......  I'm not sure if these are factoroy replacements or not but they are the Z71 logos......
My Webpage
:smash:
Thanks alot for the replies...   jr.parrish that was the # i was looking for..  are the factory decals pretty easy to remove, so i can replace them with the new ones?
Matt
Matt
I just replace the Z71 decals on my 99 with the 2001+ decals this past Sunday. I took about 45 minutes from start to finish, and I took my time. The easiest way to do it is to basically use a blowdryer. Just pass the blowdryer over the decal for a minute or two, and then kind of "pick" at a corner of it until there is enough peeled, that you can peel the whole thing off. On one side the decal came off as one piece, but on the other it peeled into a couple of pieces. Then I just used rubbing alcohol to remove the excess adhesive. The OEM decals have markings that tell you how to line the decals up. Its really a simple procedure.
You can probably see the the words and lines that help you line the up in this pic.
If you want to see before and after pics go http://photos.yahoo.com/bc/parrish_justin
  • 1 month later...
    Kirk Belch
    Kirk Belch
  • Who's Online   5 Members, 1 Anonymous, 1,071 Guests (See full list)
