95 5.7 oil pressure low
95z71performer
I recently bought a 1995 silverado with a 5.7 and the oil pressure is low...and I need an o2 sensor for the headers :flag:
any suggestions as to what could be the oil problem I believe it's the oil pan gasket because the oil pan is wet
not a bad truck for $2500
A leaky pan .. or any other gasket won't cause low oil pressure. Bad bearings will .... but before you condemn the lower end, put a GOOD gauge directly in an oil port - don't rely on the dash gauge. They're notoriously inaccurate.
I'd only replace an o2 sensor on a '95 if it was getting less than 15 mpg - just fyi & my .02 ...
When trying to locate an oil leak, remember, oil leaks down. Find and correct the highest leak you can find first.
If you are seeing low oil pressure due to low oil level, damage is done. If the oil level is low enough to allow air to be drawn into the oil pump that will cause aeration and foam in the oil passages. Normally you cannot compress a liquid(it will compress slightly, but not noticeably), but, put some air into it and it can now be compressed. The pump will not move the oil if it can compress it.
As said above, make sure oil level is full, then put a mechanical oil pressure gauge on it to test oil pressure. Acceptable oil pressure has always been expressed as 10psi per 1000 rpm. Last time I checked for a spec on a sender for oil pressure light, it was built to turn oil pressure light on at 7psi.
I might not get o2 sensors but I will get something to plug the hole in the headers and the exhaust system I'm planning on trying to do is side pipe in front of the rear tire to save some on exhaust pipe will that help anything in terms of back pressure
What we do at work when those old 350s start losing pressure is put Rotella 15-40 in them and go another 100k lol. I wouldn't worry too much, they just keep on going.
That they do but I've found out through driving my uncles truck last night that it's normal he has the exact same thing (and only 100 miles separate our odometers) except his is a stepside
And when that stops working, you go to 20w-50. :smoker::thumbs:
Oil leaking now from a weird place...the place for the dipstick and I think it needs a gasket for the oil pan as well ever seen that happen like this?
    DaleB
    DaleB
  • Who's Online   1 Member, 0 Anonymous, 1,245 Guests (See full list)
    • Common Sense Assembly   Your driveline is forgiving of the occasional mistake. It will even often forgive the random serious blunder. But it will not forgive a continuous bad habit.      What? Not everything needs to be a five thousand word essay.
    • We drove about 15 minute east today to visit a friend and saw a steep increase in price in the same county. About 50 cents a gallon steepper.
    • Sure about that? A degree wheel and a dial indicator would lower your degree of assurance in that statement. 😉    It why we have offset keys and dialable timing sprockets. Just say'n.... I've built a few and have never seen one "On the money".
    • I will admit I haven't experimented much with pressure drops beyond the numbers I put in and part of that is that the numbers I used are fairly low and then found out it would trigger regardless at that 35 psi. Having said that I had tried before had changed the placard pressures and being that I have a 1 ton set to 80 on the placard for the rear I believe it triggered close to 60, the front I don't recall now for sure but thought maybe it could get close to 45 from that factory 60 placard pressure. So I never did figure out if it was a number of psi from placard pressure to the alarm or a percentage of the total placard number as some figured it was like a 25% drop from placard pressure would trigger it. So as to try and answer your question, I believe I set the placard pressure on the front to 47 or so and while I run the front tires at 40, they have dipped below that some if its colder and I haven't put "winter air" in yet and never once have had the front alarm go off. I would say that the answer your looking for is no, that if you set your placard pressure to 45, you have a certain amount of room to drop below that pressure before the alarm will go off.    The pressures you decide to run in your truck, that ends up being what makes sense to you based on what your carrying in your truck or if towing, then have to bump them back up to something that will carry the load in the rear and the fronts typically left at the same pressure. It all comes down to that chart I put the link to and using an accurate roadside scale to be your guide, both unloaded and then loaded to know your minimum safe pressures.    I just wish GM would allow a person to change the readings for the tire pressures to the English system of pounds as I have to look at that goofy metric reading that will never ever jive in my head and will go over and change it just to figure out what they are if need be and then change it back.
    • That part I understand, that the dealer can do it. But I'm not understanding why updates that were available to the truck since it left the factory, or the dealership originally, would not still be available to it without dealer intervention.   I'm thinking along the lines of recalls. They stay available until they are completed, regardless of whether they are in warranty or not, or in the hands of the original owner or not. Why not updates as well, especially since some of those can be safety related also?
