4WD issue
When I lock my truck in 4LO the switch blinks a couple times then lights go off completely then service 4WD light comes on. If I turn the truck off then flip the key back over it says its in 4HI then lights go off and service 4WD light comes back on.
Its a 2002 Z71
Pull any C codes that will be stored, likely autozone could do it. Sounds like an encoder motor though.
Would it hurt to try it?
course not ,,,,,unless something else is wrong ,,,,ya cant return electrical parts
roll the dice bud,,,good luck,,,,
bill it to efritz if it doesnt work ,
Ya you need proper diagnostics, You can't just guess or it gets expensive in a hurry.
