I'm an idiot
C25A1guy
I dicked up my bullet button install on my AR. I installed the spring under the shroud instead of in it. Now I'm painstakingly trying to remove the little castle nut inside so I can get it back together again the right way.
    Dom Colussi
    Dom Colussi
  • Who's Online   4 Members, 0 Anonymous, 693 Guests (See full list)
