weird
ckwlsn
5.6 2007 silveraldo stated smoking (heavy) with a funny smell. looked as if a liquid was coming out of tailpipes it never missed. I was sitting still at a drive threw and then it quit ? It seems i did not loose any water or oil and there is no water in my oil. Truck is running as nothing happened. 165,000 miles
I would imagine the engine size is wrong to FFS. Should have been 5.3. If the smoke had a sweet smell to it (if you breath it in through your mouth it may make your mouth water. If so, that is coolant. It does not take much to create a good steam cloud. It may only leak at certain engine temp and coolant pressure as well. Keep an eye on the coolant level,
You could try pulling the plugs out and looking at the colour of the tip. Look for one plug being a different colour. I think you will find you have either a head gasket leaking into the cylinder, or a porous casting leaking into one cylinder.
Don't be so quick to think the oil is just oil. Oil and coolant don't mix, and coolant will sit at the bottom of the pan. If this is just starting, it may not have made it down to the pan yet.
It is 5.3. Doug I thought same I'm going to change oil tomorrow. let you know what i come up with. What made weird to me was the way it started and stopped. I've blown a head gasket and it missed a little.
Head gaskets can leak a few ways. If you have the very beginning of a leak between a water passage and the cylinder, you may not feel anything. It will get worse over time, and will cause a slight miss once it starts to leak over a wider range of engine temperature. I think you will find the leak has just started, only leaks under specific conditions. A head gasket can act like a flapper valve, only letting coolant into cylinder when coolant is under pressure, and engine is on intake stroke. Once pressure in cylinder is higher than coolant pressure, the engine will push cylinder gases into coolant. Eventually the gasket will fail completely and will leak under all conditions. You can get a tester that can test for combustion fumes in the coolant.
Thanks: I had a 750 4wheeler do the that. It would loose a little water over time . It told on itself by putting to much pressure on the coolant system and blew the coolant jug lid off.
I saw a product on tv the other day that claims to be a replacement engine coolant that does not expand when heated, its natural boiling point is 180 degrees C, freezing point is -40c. I did not catch the name of the product, but, it has a special fluid you use first to remove all water and glycol from the system. This fluid can be filtered when you remove it from the system and reused on another engine to remove water and coolant. This new waterless coolant does not create pressure when heated to operating temp, so, that means you do not need a rad cap, you could use just a twist or threaded cap. This stuff was 4 or 5 times the price of glycol coolant. It does not need changing, ever.
With no pressure being created, any small leaks you have won't leak, those border line water pump leaks will have to wait until they are bigger leaks. Maybe someone here caught the name of the product. The show was the one with the two guys from England that pick up a car, redo it and sell it off at end of show. Mechanics name is Ed.
Thats the show. I looked it up and found the episode. It was the one on the triumph TR6. All it says about the coolant though is "conventional water based coolant flushed and replaced with synthetic 'water free' coolant". They never turned the bottle to show the label.
I know this is getting off topic, but, I really like the idea of no pressurized cooling system. The pressurized cooling system we currently use, makes use of the natural pressure increase due to thermal expansion to raise the boiling point of the coolant. Pretty sure I was told(back in trade school days before Canada went metric) it was about 3 degrees increase for every pound of pressure. So the 14 pound rad cap could keep coolant from boiling up to just over 250 degrees. Problem with that is that as soon as the cap vents, you get this superheated steam coming at you, with water that is way over its boiling point now that the cap released pressure. This new fluid can't ever do that. The fluid can get very hot, but it is a stable hot liquid. Lack of pressure is easier on all parts of cooling system. They also claim never change since the liquid does not corrode or become acidic like glycol does.
    DaleB
    DaleB
  • Who's Online   1 Member, 0 Anonymous, 1,273 Guests (See full list)
    • My truck is a ¾ ton but my placard also says 80 for the rear tires, I think I might have the upgraded suspension to the 3500 series maybe.   I put my air down to 60 and the light was still on, and there was no way I was putting over 60 psi in the rear empty and not towing because I knew the actual number Toyo gave me and I didn't wanna ruin the center of my tires!   And you actually can change it in the settings from metric or is and it will show kph or mph then when you go into your tire settings it will be either psi or kpa, but it would be nice to just change it directly on the tire psi page
    • Common Sense Assembly   Your driveline is forgiving of the occasional mistake. It will even often forgive the random serious blunder. But it will not forgive a continuous bad habit.      What? Not everything needs to be a five thousand word essay.
    • We drove about 15 minute east today to visit a friend and saw a steep increase in price in the same county. About 50 cents a gallon steepper.
    • Sure about that? A degree wheel and a dial indicator would lower your degree of assurance in that statement. 😉    It why we have offset keys and dialable timing sprockets. Just say'n.... I've built a few and have never seen one "On the money".
    • I will admit I haven't experimented much with pressure drops beyond the numbers I put in and part of that is that the numbers I used are fairly low and then found out it would trigger regardless at that 35 psi. Having said that I had tried before had changed the placard pressures and being that I have a 1 ton set to 80 on the placard for the rear I believe it triggered close to 60, the front I don't recall now for sure but thought maybe it could get close to 45 from that factory 60 placard pressure. So I never did figure out if it was a number of psi from placard pressure to the alarm or a percentage of the total placard number as some figured it was like a 25% drop from placard pressure would trigger it. So as to try and answer your question, I believe I set the placard pressure on the front to 47 or so and while I run the front tires at 40, they have dipped below that some if its colder and I haven't put "winter air" in yet and never once have had the front alarm go off. I would say that the answer your looking for is no, that if you set your placard pressure to 45, you have a certain amount of room to drop below that pressure before the alarm will go off.    The pressures you decide to run in your truck, that ends up being what makes sense to you based on what your carrying in your truck or if towing, then have to bump them back up to something that will carry the load in the rear and the fronts typically left at the same pressure. It all comes down to that chart I put the link to and using an accurate roadside scale to be your guide, both unloaded and then loaded to know your minimum safe pressures.    I just wish GM would allow a person to change the readings for the tire pressures to the English system of pounds as I have to look at that goofy metric reading that will never ever jive in my head and will go over and change it just to figure out what they are if need be and then change it back.
