UQA Bose explaination
My brother has an 04 Buick Rainier CXL with the Bose and the RPO is UQA. Where in the hell is the sub located on this body? On my Sierra it was in the Console.
  • 4 weeks later...
Wow no help. I want to do a stereo build for my brother but need to know what it already has
If I remember correctly it is behind the driver rear interior panel in trunk. It should be a 6-8 in sub
Rear ac if equiped is on the other side
Hmmm I dont even remember seeing a grille for it. I need to plan it out because it would be for his birthday
I worked mainly on trailblazers and envoy but they were all similar. I believe i only built one ranier saab and i believe izuzu that used this platform.
It is basically a decked out trailblazer
It has been ten years since i have had one apart. Lol
    Brendan C
    Brendan C
  • Who's Online   2 Members, 0 Anonymous, 1,003 Guests (See full list)
