burning smell
Got the truck back today. Apparently it was the HPF gasket, not the pump itself. Also drained the 1/2 quart of oil that they over filled two weeks ago at my first oil change. Road tested and they said no more leaks, although now my cab smells like there's a gallon of gasoline in the vents. Hope it airs out quick because nothing like smelling gas in my 6 month old $40k plus truck.
Hopefully. Good luck that sucks. If it still stinks take it back and demand some goodies. It's worth a try.
  • 1 year later...
I'll revive an old thread. I just picked up a brand new 2018 GMC Sierra Denali 2500 HD diesel. It had 27 miles on it when I picked it up. I drove from Illinois where i purchased it to Indiana where I live. I would expect some mild smells from the "newness" burning off. I got home and parked it in my garage after driving 100 or more miles. No smell. Next day (yesterday) drove it around town and didn't notice anything. Got home, pulled into my garage and it smelled so bad I was afraid it might burst into flames and start the house on fire. I checked engine bay - nothing. I checked under truck - nothing. I checked oil level to just make sure - all good. I then went out again last night  - a 5 mile round trip, pulled into garage and my wife was now fearful that it might start the house on fire. It's 15°F here. Could that have something to do with it? The only other thing I could think of is could one of the disc brakes might be locked on the rotor? With the torque of the 6.6 Duramax, I might not notice. If that were the case though I think the truck would pull to one side. I can'  take it anywhere for a few days since today is NYE and tomorrow is New Years Day. Any ideas? I guess it's under warranty but I don't want to go through that hassle plus I just got finished installing the crossover toolbox & tonneau cover and I don't want to have to do that on a new truck if this one dies before it's first week.
Same here, just bought a new 2500 hd high country.  just under 300 miles and it hit me hard in the face.  I first thought it was the traffic.  When i got home the smell was there.  I popped the hood and it was there as well.  I can't find any leaks that i can see.  I hope this is not a big problem.  6.6 Duramax as well.   Guess this could be the start of a recall.  I hope it is not serious.  I really love this truck.
I bought a new 2017 denali 2500 diesel in August and have smelled the burning rubber 3 different times now, seems to occur mostly during slow traffic conditions.  I've got just over 10,000 miles on it so I would guess the "new" smells should have run their course already.  Also, just this morning the engine light came on so not really sure what that's about yet, I'll post an update when I find out.
  • 1 year later...
I had the same problem tonight.  Coming from under the bed of the truck...2600 miles on a 2500 Duramax.  Only drove 10 miles.  It smelled like a clutch burning..Also i just drove it 15 hours across the country and had no smell...this was a 10 mile run in town.
    DaleB
    DaleB
  • Who's Online   0 Members, 0 Anonymous, 1,188 Guests (See full list)
    • Common Sense Assembly   Your driveline is forgiving of the occasional mistake. It will even often forgive the random serious blunder. But it will not forgive a continuous bad habit.      What? Not everything needs to be a five thousand word essay.
    • We drove about 15 minute east today to visit a friend and saw a steep increase in price in the same county. About 50 cents a gallon steepper.
    • Sure about that? A degree wheel and a dial indicator would lower your degree of assurance in that statement. 😉    It why we have offset keys and dialable timing sprockets. Just say'n.... I've built a few and have never seen one "On the money".
    • I will admit I haven't experimented much with pressure drops beyond the numbers I put in and part of that is that the numbers I used are fairly low and then found out it would trigger regardless at that 35 psi. Having said that I had tried before had changed the placard pressures and being that I have a 1 ton set to 80 on the placard for the rear I believe it triggered close to 60, the front I don't recall now for sure but thought maybe it could get close to 45 from that factory 60 placard pressure. So I never did figure out if it was a number of psi from placard pressure to the alarm or a percentage of the total placard number as some figured it was like a 25% drop from placard pressure would trigger it. So as to try and answer your question, I believe I set the placard pressure on the front to 47 or so and while I run the front tires at 40, they have dipped below that some if its colder and I haven't put "winter air" in yet and never once have had the front alarm go off. I would say that the answer your looking for is no, that if you set your placard pressure to 45, you have a certain amount of room to drop below that pressure before the alarm will go off.    The pressures you decide to run in your truck, that ends up being what makes sense to you based on what your carrying in your truck or if towing, then have to bump them back up to something that will carry the load in the rear and the fronts typically left at the same pressure. It all comes down to that chart I put the link to and using an accurate roadside scale to be your guide, both unloaded and then loaded to know your minimum safe pressures.    I just wish GM would allow a person to change the readings for the tire pressures to the English system of pounds as I have to look at that goofy metric reading that will never ever jive in my head and will go over and change it just to figure out what they are if need be and then change it back.
    • That part I understand, that the dealer can do it. But I'm not understanding why updates that were available to the truck since it left the factory, or the dealership originally, would not still be available to it without dealer intervention.   I'm thinking along the lines of recalls. They stay available until they are completed, regardless of whether they are in warranty or not, or in the hands of the original owner or not. Why not updates as well, especially since some of those can be safety related also?
