Finally !
I got word from the dealer that my truck is shipping.
Here is my vin #
3gcuksejxeg347735
Is there a way to track it?
My VIN ends with 344355 and it shipped early last week. If you have the order # you can track it from chevrolet.com. Under the OWNERSHIP header at the bottom of the page click "Track your order".
Tapatalk via iPhone 5s
My VIN ends with 344355 and it shipped early last week. If you have the order # you can track it from chevrolet.com. Under the OWNERSHIP header at the bottom of the page click "Track your order". Tapatalk via iPhone 5s
I spoke to support. They provided me with my order number. Mine is supposed to arrive on feb 6. Do you know when yours is going to arrive?
    Brendan C
    Brendan C
  • Who's Online   3 Members, 0 Anonymous, 1,049 Guests (See full list)
