Will 285/55-20's fit?
Crf13
Just wondering if anybody is running 285/55-20's on their truck? I just purchased a 2014 Silverado Z71 and the tires don't give it justice. I want a beefier tire but don't want to lift it yet. So I'm going up just one size to get better choices in tires. Is anybody running anything bigger than stock without lifting or leveling their truck and they don't rub?
Thanks
Probably would be a really close fit. That would be 32.3" height, 11.22 wide.
I am running a 2.5" TGC level up front and was able to fit 305/50/20 - 32.6 height, 12.4" wide - touches the sway bar at full lock.
  • 3 weeks later...
I can tell you this i have a 2014 with a 2.5 RC lift and run 275-60-20 zeon ltz tires
(33.2 inches) and they have a slight rub at full lock. I think with the stock setup you will be hard pressed to go much taller then the stock tires.
  • 1 month later...
what is it rubbing? The inner fender?
Very slight rub full lock to the left on the inner fender well. no big deal..
    TopBo
    TopBo
  • Who's Online   1 Member, 0 Anonymous, 2,798 Guests (See full list)
