DIC Error Messages
Recently began getting a Service Trailer Brake system message. It has been to cold to check it out. Thought there may be water in the 7 pin connector IDK since it has not been used since summer.
Last night, I got a Traction Control not working message. But it seemed liked it did work. I have not gone out and played with it yet. Damn what could cause these problems?
I have not checked fuses. Could it be as simple as that?
Any thoughts or experiences would be helpful!
Thanks,
Ron
Hello Keepontrying,
I'm sorry to hear of the concerns you are having. Have you been to the dealer yet? I can help! If you'd like my assistance, please private message me with your name, phone number, address, VIN, current mileage and involved dealer. I look forward to hearing from you!
Thank you,
Andraya R.
GM Customer Care
Spoke to a service tech and another mechanic. Both said these error messages are typicall due to a MAF/intake tube/throttle body issue-typically, Wife drove truck all week and said messages were there each day. 36 degrees out today and I went to check it out and there are no error messages. Could those messages have been due to the extreme clold over several days? Moisture in the intake?
I will keep an eye on it. Any input is appreciated,
Thanks,
ron
No Traction control error messages for 2 weeks. Still getting the service trailer brake system error message. No garage to work in so will be a spring project.
Thanks,
Ron
    Brendan C
    Brendan C
  • Who's Online   2 Members, 0 Anonymous, 750 Guests (See full list)
