1/18 scale HD
Chev4Ever
It would figure that i just bought the non HD 3500 duallie... I was looking for rather a red or black one but they came in tan or white..
*kicking myself for not asking the sales guy about this ohe*
For the people who collect what is your pride and joy??
I have 2.. A 1/18th black Z06 and my ultimate a 67 Camaro SS with every detail carried out in the fullest!! Not bad for 260 bucks for the one model alone :D
I ve got about 1200 bucks spent in models *Ya its a horrible habbit!!*
Quote from MountaineerTom 99Z71, posted on Nov. 06 2001,6:06
chevy4x4trucks,
Where did you get the 1/18th scale red one?  What brand is it?
Thanks.
Couldn't tell you the brand off hand, they have a few different ones, I get all my models from
http://www.collectablediecast.com
They have the best prices and the biggest selection.
My favorite models would have to be the 1/18th Humvee and the 1/24th '67 Camaro
    Brendan C
    Brendan C
  • Who's Online   4 Members, 1 Anonymous, 1,163 Guests (See full list)
