Summer Wheels
Meisterbk
As the winter that won't end slowly grinds to a hault, when do those of you north of the Mason/Dixon plan to install your summer wheels? Specifically the chrome. I'm thinking of applying some Adams Quick Sealant this weekend and going for it.
I live around Buffalo NY and usually wait until around the second good rain until I break out the show truck and car. I just ordered new shoes for my 2014 so I'm not sure how long I will be able to wait to put these on. But mine are black. On my show car and truck I learned the hard way that patience is a virtue. That salt can be nasty and cause you more problems than it's worth.
As it snowed here in NE ohio today its still a few weeks away
Sent from my SCH-I535 using Tapatalk
    President Roberto
    President Roberto
  • Who's Online   0 Members, 0 Anonymous, 255 Guests (See full list)
