avitar
Ox1
How doo I get my avitar loaded on to this site. I see that others have it. ??
All I get is this - Sorry, that is not a valid file extension
i'm not sure why, but when i click its adding a %2E to the file name. I think thats your problem. You need to figure out why its doing that
Well, I tried to drop a / and to my suprise the file still comes up, but that is the correct address. Either way it is still a no-go, I still get the same error. ???
OH, the %2E is part of the file name too. I have to host it elsewhere right? I can't upload directly to this site can I?
My avitar (who ever came up with that name anyhow?) is either 100 or 120 pixels, but as I read the directions it will resize as needed? It is 39kb, is there a possability it is too big of a file size? I don't think I saw anything aboot that. (especially if it is not hosted here)
Thanks for the ideas, keep'm comming.  :thumb:
EDIT: -------------
Well, it looks like it took both ideas at the same time to make it work! I can't believe that I can drop four items and add a dot and still get the same thing to come up. ??? Heck any other time if I leave out one little thing I get nothing - OR something altogether diff. Oh well, now I know what I need to doo to get some things up here eh? Thanks fellers!  Now, armed with this info, I will see if I can get a pic intered into my profile now. (that didn't want to work either)
NOW if I could just finger out why this site doesn't want to keep my logged in!  :cool:  I have to physically log in when I enter, even tho I have checked the "remember me" item. It is HARD work! LOL! ?? But things are getting better.
  • 3 weeks later...
    Sothpaw27
    Sothpaw27
  • Who's Online   1 Member, 0 Anonymous, 410 Guests (See full list)
    • Can it still be Assembled II?   Viscosity on the decline by various means. Heat on the rise making that worse. Engine RPM in the tank. Smaller motors with more boost trying to emulate an electric motor. Full torque, zero rpm. Then we will triple the OCI. Argh.    But wait....there is more. LSPI has pushed a shift from Ca to Mg and as that cost more PLUS the run to lower sulfur compounds the TBN is moving in the wrong direction for the increased OCI's demanded.    That not being enough to placate a demand for a parameter they can't measure the other sulfur bearing compounds are also under attack. That would be zinc and phosphorus sulfonate compounds. To some degree those are being replaced with boron esters and others, i.e. titanium ect. All of which have shorter service lives. And there there is the "Secrete Sauce" marketing for AW adds that 'Can't be detected by UOA's" but trust me because I (the blenders) never ever lie.    Spoiler alert; ALL additives are sacrificial! Smaller amounts of the old blended with less robust versions of the new do not equal longer service lives. So what are the blenders recommending? Wait for it.......   MOVING THE GOAL POSTS! OMG      Let's declare the long standing TAN/TBN crossover irrelevant and tell people that soot is a great 'graphite' based lubricant which can aid tribo films. Wait, what? Let's declare that the standards used for oxidation and nitration were to conservative and can be expanded. Let's tell them that because GDI fuel dilution, although being a VISCOSITY KILLER and an acid generator is actually okay because we have better base oils that limit viscosity failure limits. (Said knowing this is measured in fractions of a centipoise and in bases not commonly used in shelf oils)   Lying from the heart is not just the new normal but we have a public, a very young public, that is so ignorant of the facts and so sure of their "RESEARCH" into AI driven models base in regurgitated  instead of scientific research based unvarnished, peer reviewed FACTS that the incoming guard is loosing their grip on reality and the OEM's are tickled pink while the blends bend the knee.    You have an ever limited set of tools to work with. And sooner or later those will be taken from you as the API and the EPA strangle the last remaining fluids from the system. What you have left is your wits. If you care to use them.    At some point in the very near future it will not longer be possible to do "What is best for the machine", and be replaced with "The best you have access too". You WILL be rewarded with half the life and twice the cost. That isn't that hard to predict.
