Tyson's New Tat
elboberino
Actually at his press confernce today he said it is not even half way finished.  He just stopped because everyone is making such a big deal about him getting it this close to his next fight.
Wait now....at the weigh-in today, he refused comment. He will comment later when it is completed! ;)
