2001 Silverado HVAC Issues
deanemf
Hello,
First, I know this has been asked many times before, I have done a search and could not find my exact issue on the forum.
I have a 2001 Silverado and when I bought it, the heat and ac worked fine independently, but once the heat was on, it would get stuck on and not go back to AC. This would only be fixed by turning off the car for a short period which “reset” something that was stuck and the AC would work.
In order to fix this I purchased a new blend door actuator which gave me the same result. Now, several months after changing the actuator the truck is stuck on heat completely and will never go to AC. What could be the issue? I have tried removing the battery to re-calibrate the hvac but that did not help. I did admittedly run the new actuator while not connected to the door but only for a quick second to verify it worked.
Any help would be appreciated, thanks.
-Matt
It can't read HVAC codes if there are any present. What Rob is looking for are codes indicating the HVAC controller is having issues itself or codes indicating other problems
Also you shouldn't have operated the motor while it was out
There was an issue with the connections on the passenger junction block. Its located behind the panel at the end of the dash when you open the door.I would try unplugging all the connectors and then putting them back. I am not sure if this applies to you yr model but its worth a try. Probably gonna take a tech 2 or some other higher end scanner to get HVAC codes.
Thanks for the info everyone.
I ended up taking the truck to my mechanic and paying for the repair. Turns out when I had replaced the actuator I put in the wrong part number actuator. My mechanic replaced it with the correct actuator and the trucks HVAC works great now!
Thanks again for the info
Sent from my XT907 using Tapatalk
    • We drove about 15 minute east today to visit a friend and saw a steep increase in price in the same county. About 50 cents a gallon steepper.
    • Sure about that? A degree wheel and a dial indicator would lower your degree of assurance in that statement. 😉    It why we have offset keys and dialable timing sprockets. Just say'n.... I've built a few and have never seen one "On the money".
    • I will admit I haven't experimented much with pressure drops beyond the numbers I put in and part of that is that the numbers I used are fairly low and then found out it would trigger regardless at that 35 psi. Having said that I had tried before had changed the placard pressures and being that I have a 1 ton set to 80 on the placard for the rear I believe it triggered close to 60, the front I don't recall now for sure but thought maybe it could get close to 45 from that factory 60 placard pressure. So I never did figure out if it was a number of psi from placard pressure to the alarm or a percentage of the total placard number as some figured it was like a 25% drop from placard pressure would trigger it. So as to try and answer your question, I believe I set the placard pressure on the front to 47 or so and while I run the front tires at 40, they have dipped below that some if its colder and I haven't put "winter air" in yet and never once have had the front alarm go off. I would say that the answer your looking for is no, that if you set your placard pressure to 45, you have a certain amount of room to drop below that pressure before the alarm will go off.    The pressures you decide to run in your truck, that ends up being what makes sense to you based on what your carrying in your truck or if towing, then have to bump them back up to something that will carry the load in the rear and the fronts typically left at the same pressure. It all comes down to that chart I put the link to and using an accurate roadside scale to be your guide, both unloaded and then loaded to know your minimum safe pressures.    I just wish GM would allow a person to change the readings for the tire pressures to the English system of pounds as I have to look at that goofy metric reading that will never ever jive in my head and will go over and change it just to figure out what they are if need be and then change it back.
    • That part I understand, that the dealer can do it. But I'm not understanding why updates that were available to the truck since it left the factory, or the dealership originally, would not still be available to it without dealer intervention.   I'm thinking along the lines of recalls. They stay available until they are completed, regardless of whether they are in warranty or not, or in the hands of the original owner or not. Why not updates as well, especially since some of those can be safety related also?
    • That's good to know, but I don't think I'll even be running them under 45 in the rear  unless it's on the sand or something but will only be for a short distance anyways!    I didn't read all the instructions in the booklet yet, but do you know let's say I set the rear psi on the placard to 45, will the warning light come on soon as it drops under 45 or is there a percentage it has to drop from the set value before the warning light is triggered?
