Nav question
I dont have nav yet but ill be adding it soon... if I am on the radio screen (main screen) and turn off truck, turn it back on, it goes right to the radio screen. If you have nav, are on that screen, turn truck off, back on, does it return to nav or does it go to to the home screen? Thats what it does with my onstar nav, but wasnt sure if the native nav app does the same
Sent from my SM-N900V using Tapatalk
Nav comes back up. What ever is on screen comes back up after a startup. Exception is if you send the nag an address from your phone. A message comes up when you startup even if you were on xm or something else.
    • My brother has an Escalade. The warranty has expired so he told his wife to go to the Valvoline quick lube he uses some times. They told her if her car was a 2020 and newer 6.2 engine they wouldn’t touch it. Hers is a 2019, so they did the oil change.
