Service Stabilitrak and ABS
Clo004
Got in the truck today and Service Stabilitrak and park assist disabled popped up on the DIC. I also saw the ABS light was lit up on the instrument panel. I will be a few days before I can get it to the dealership. Anybody have an idea what caused this?
Guess I should tell you I am driving a 2014 Crew Cab LTZ Z71 5.3L
I just changed out my hub and abs sensors. Disconnect all of your abs connectors and reattach them back. This makes sure your are not disconnected. Next, check your fuse box for Abs fuse 25
Remove the fuse and check to see if it damaged. Next, leave the fuse out and remove the negative and than power connector from your battery. Make sure they don’t touch the battery. Keep disconnected for 30 to 45 minutes. Once the time has passed. Put the fuse back in, reconnect the battery.
You will have to drive your car for a few minutes to reset it self.
Let me know how this works out. I just took care of this problem today, after hours of research.
Only thing I did was let the battery stay disconnected over night, due to the time of working on my truck.
Keep me posted.
  • 1 year later...
I have a 2018 Silverado with 28 thousand miles. that i just purchased from a dealer. It has 9in lift and 35in tires. Everything was working properly until i hooked a trailer to it and plugged the trailer lights in. When i got back into the truck the abs light and stabilitrac light was on. i read a few forms saying it could be the fuse but all fuses checked out. I haven’t checked wheel bearings and such yet. It just seems odd that the abs light and stabilitrac light will come on when the trailer is hooked up and will not go off now that the trailer is discounted. Any ideas?
    Whit.the.COB
    Whit.the.COB
  • Who's Online   2 Members, 0 Anonymous, 1,231 Guests (See full list)
    • I did the new thermostat after doing a 'flip' for a year. Runs as cool one way as the other in the summer but in the winter there is a bit of a floor. Yellow with the new 70 C thermostat. My data over the life of the unit to date. Still need more cooler. Anyway that floor helped both winter fuel economy and shift quality in the winter. I found it a good balance.
    • Evan Williams Bottled in Bond   So pouring the last of a bottle of Evan Williams Black label last night I set off the the state store for a refill only to be denied the by an empty shelf. Rats.    What the did have was a bottle of Evan Williams Bottled in Bond. 100 proof. Hum, a few bucks more but a known distiller. Lets have a swing at it. ( I have before )    Cracked it open and pour a serving over ice. Hum.... more heat, yes. More alcohol naturally. But the barreling not the proof brings the taste and this one came up short.    Oh is was familiar but the heat ran the barrel over like a Peterbilt runs over a squirrel. Could use a heavier toasting of the oak me thinks or perhaps a longer barreling. Who knows. But what I can say is ice or a water back isn't the answer. What kills one kills them both. Sad. It is a pleasant drink....if you have little to compare it to.
    • I've had exactly one set of Bridgestone. Lasted five year and 125,000 miles and had I known better 15oK would have been a cake walk. I would have bought a like set had they not tripled in price since the first set. I removed them at said mileage with 5/32" remaining in dead even wear all four. They were fuel efficient, quite, comfortable and predictable.    Early on I got a very good alignment checked at least once a year, sometimes twice; kept the tires properly inflated, balanced and rotated. And I've found that many a tire issue can be avoided with great maintenance practices. Lot's of tire dealers will do rotation and balance (simple) for free for as long as you own the tire they sold you so no excuse not to.    Bead prep, alloy integrity and stem health have a huge impact on inflation stability. There are more mountings done poorly that perfectly. Finding a good tire guy is gold and as important as finding a tire you like.    That 3X price increase now two sets of "other tires' later is starting look like a bargain.      Bad maintenance kills more tires than bad tires.
    • Atlas, you kill me As aggravating as a project like this can be you have been unable to hide your fascination with learning and using that angst against this beast like a Ninjitsu Master. It amuses you, admit it now.      BTW, love your writing style. 😉
    • I gotta say, I'm enjoying your narration. The troubles you've been having are amusing as you describe them. It's good to see that you're finally getting some satisfaction out the old beast though.
